Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP 250 G7 Battery Replacement
Ce dont vous avez besoin
  1. HP 250 G7 Battery Replacement, Lower Case: étape 1, image 1 de 2 HP 250 G7 Battery Replacement, Lower Case: étape 1, image 2 de 2
    • Unplug the charger and all peripheries. Shut down the laptop before beginning disassembly.
    • Flip the laptop so its underside is facing up.
    • Use a hair dryer to lightly heat the rubber feet.
    • Use a spudger to lift and remove the rubber feet.
    • If you intend to reuse the feet, take care not to tear or warp the rubber feet during removal. Reapply adhesive during reinstallation.
    Demander à FixBot
    Ajouter un commentaire
  2. HP 250 G7 Battery Replacement: étape 2, image 1 de 3 HP 250 G7 Battery Replacement: étape 2, image 2 de 3 HP 250 G7 Battery Replacement: étape 2, image 3 de 3
    • Remove the eleven 9 mm-long Phillips #1 screws securing the lower case.
    Demander à FixBot
  3. HP 250 G7 Battery Replacement: étape 3, image 1 de 3 HP 250 G7 Battery Replacement: étape 3, image 2 de 3 HP 250 G7 Battery Replacement: étape 3, image 3 de 3
    • Insert an opening pick or opening tool into the seam between the lower case and palm rest assembly.
    • Slide the opening pick around the entire perimeter, while prying every couple of centimeters to release the retaining clips.
    • Remove the lower case.
    Demander à FixBot
  4. HP 250 G7 Battery Replacement, Battery: étape 4, image 1 de 1
    • Remove the three 8 mm-long Phillips #1 screws securing the battery.
    Demander à FixBot
  5. HP 250 G7 Battery Replacement: étape 5, image 1 de 2 HP 250 G7 Battery Replacement: étape 5, image 2 de 2
    • Lift the battery up and away from the connector.
    • Remove the battery.
    Demander à FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 autres ont terminé cette réparation.
Erik Romo
Membre depuis le 03/11/26
519 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 23
30 derniers jours : 24
Total : 113
