Aller au contenu principal
HP Chromebook 11 G4 Keyboard Replacement
Ce dont vous avez besoin
  1. HP Chromebook 11 G4 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 Keyboard Replacement: étape 2, image 1 de 2 HP Chromebook 11 G4 Keyboard Replacement: étape 2, image 2 de 2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 Keyboard Replacement: étape 3, image 1 de 2 HP Chromebook 11 G4 Keyboard Replacement: étape 3, image 2 de 2
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 Keyboard Replacement: étape 4, image 1 de 1
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 Keyboard Replacement: étape 5, image 1 de 2 HP Chromebook 11 G4 Keyboard Replacement: étape 5, image 2 de 2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 Keyboard Replacement: étape 6, image 1 de 1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 Keyboard Replacement: étape 7, image 1 de 3 HP Chromebook 11 G4 Keyboard Replacement: étape 7, image 2 de 3 HP Chromebook 11 G4 Keyboard Replacement: étape 7, image 3 de 3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 Keyboard Replacement: étape 8, image 1 de 1
    • Remove the keyboard assembly by lifting it off the laptop base.
3 autres ont terminé cette réparation.
Jair Herrera
Membre depuis le 04/26/17
694 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S16-G5, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 membres
15 tutoriels rédigés
3 commentaires
How do you remove the keyboard from the assembly though? And I wish there was a mention of the fact that the heat sink is attached to the keyboard assembly.
Kyle B - Réponse
Same question as the person above. I need to remove the keyboard from the assembly.
Stephen Mason - Réponse
If you look up the parts you'll see that the entire top panel and keyboard are one assembly.
Nacho Biniz - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 24
Total : 9,155
