Aller au contenu principal
HP Elitebook x360 1040 G5 Battery Replacement
Ce dont vous avez besoin
  1. HP Elitebook x360 1040 G5 Battery Replacement, Lower Case: étape 1, image 1 de 2 HP Elitebook x360 1040 G5 Battery Replacement, Lower Case: étape 1, image 2 de 2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Battery Replacement: étape 2, image 1 de 2 HP Elitebook x360 1040 G5 Battery Replacement: étape 2, image 2 de 2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Battery Replacement, Battery: étape 3, image 1 de 2 HP Elitebook x360 1040 G5 Battery Replacement, Battery: étape 3, image 2 de 2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Battery Replacement: étape 4, image 1 de 3 HP Elitebook x360 1040 G5 Battery Replacement: étape 4, image 2 de 3 HP Elitebook x360 1040 G5 Battery Replacement: étape 4, image 3 de 3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
Corey Agena
Membre depuis le 04/21/19
794 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S1-G4, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S1-G4, Maness Spring 2019
CPSU-MANESS-S19S1G4
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 46
Total : 2,156
