Aller au contenu principal
HP Mini 110-1046NR Speakers Replacement
Ce dont vous avez besoin
  1. HP Mini 110-1046NR Speakers Replacement, Battery: étape 1, image 1 de 3 HP Mini 110-1046NR Speakers Replacement, Battery: étape 1, image 2 de 3 HP Mini 110-1046NR Speakers Replacement, Battery: étape 1, image 3 de 3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. HP Mini 110-1046NR Speakers Replacement, Keyboard: étape 2, image 1 de 2 HP Mini 110-1046NR Speakers Replacement, Keyboard: étape 2, image 2 de 2
    • With the screen closed, turn your netbook around so that the battery slot is facing you.
    • Remove the three 2.9mm screws in the battery slot.
    • This step can be made easier by using a magnetic screwdriver.
  3. HP Mini 110-1046NR Speakers Replacement: étape 3, image 1 de 3 HP Mini 110-1046NR Speakers Replacement: étape 3, image 2 de 3 HP Mini 110-1046NR Speakers Replacement: étape 3, image 3 de 3
    • Flip the netbook upright, and open the screen as far as it will go.
    • Pry up the keyboard from the middle of the top edge.
    • Insert the flat end of the spudger between middle of the the top edge of the keyboard and the plastic frame behind it.
    • Pry the keyboard up until it pops out or until you can grab it with your fingers, and then pull gently until it pops out on both sides.
    • Do not pull the keyboard out immediately - there is a potentially fragile ribbon cable that attaches to the motherboard behind the keyboard.
  4. HP Mini 110-1046NR Speakers Replacement: étape 4, image 1 de 3 HP Mini 110-1046NR Speakers Replacement: étape 4, image 2 de 3 HP Mini 110-1046NR Speakers Replacement: étape 4, image 3 de 3
    • Flip the keyboard over (toward you) by pivoting it about the lower edge, and lay it upside down on top of the touchpad area to reveal the ribbon cable.
    • Lightly pull up on the black tab on top of the keyboard ribbon cable until it hinges toward you and releases the ribbon cable end.
    • Pull the ribbon cable backward and out of the receptacle. This should not require any effort.
  5. HP Mini 110-1046NR Speakers Replacement, Hard Drive: étape 5, image 1 de 3 HP Mini 110-1046NR Speakers Replacement, Hard Drive: étape 5, image 2 de 3 HP Mini 110-1046NR Speakers Replacement, Hard Drive: étape 5, image 3 de 3
    • Remove the three screws holding down the hard drive. Use a Phillips PH0 screwdriver for the two silver, 3.4mm screws on the right, and use a PH1 for the black, 10.3mm screw on the left.
    • It is not necessary to fully remove the 10.3mm screw, but if you do, be careful to not lose the spring.
  6. HP Mini 110-1046NR Speakers Replacement: étape 6, image 1 de 3 HP Mini 110-1046NR Speakers Replacement: étape 6, image 2 de 3 HP Mini 110-1046NR Speakers Replacement: étape 6, image 3 de 3
    • As shown on the top face of the hard drive itself, pull hard drive left using the black tab until the hard drive is unplugged and entirely released from its receptacle.
    • Lift the hard drive out of the laptop.
    • Place the hard drive in an anti-static bag to reduce the likelihood of damaging it with static electricity.
  7. HP Mini 110-1046NR Speakers Replacement, Memory Card Cover: étape 7, image 1 de 3 HP Mini 110-1046NR Speakers Replacement, Memory Card Cover: étape 7, image 2 de 3 HP Mini 110-1046NR Speakers Replacement, Memory Card Cover: étape 7, image 3 de 3
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
  8. HP Mini 110-1046NR Speakers Replacement, Keyboard Bezel: étape 8, image 1 de 2 HP Mini 110-1046NR Speakers Replacement, Keyboard Bezel: étape 8, image 2 de 2
    • It is not necessary to remove the memory card for this step.
    • Remove the 4.9mm screw located to the right of the of the memory card using a PH1 screwdriver.
  9. HP Mini 110-1046NR Speakers Replacement: étape 9, image 1 de 3 HP Mini 110-1046NR Speakers Replacement: étape 9, image 2 de 3 HP Mini 110-1046NR Speakers Replacement: étape 9, image 3 de 3
    • Pry the four feet with the pick-end of the spudger. These are glued down, so this may require some force.
    • Remove the 6mm PH1 screws located under each foot.
  10. HP Mini 110-1046NR Speakers Replacement: étape 10, image 1 de 3 HP Mini 110-1046NR Speakers Replacement: étape 10, image 2 de 3 HP Mini 110-1046NR Speakers Replacement: étape 10, image 3 de 3
    • Flip the netbook over and remove with a PH1 screwdriver the eight 5.9mm screws that secure the keyboard bezel in place.
    • Only remove the black screws with "M2.5x6" markings next to them. All others are unnecessary.
    • Taking the keyboard bezel off without removing the hard drive may be possible, but there is a risk of breaking several tabs on the keyboard bezel located between the hard drive and the frame of the computer.
    • Using the flat end of the spudger or pry stick, pry the keyboard bezel away from the base by wedging the tool between the base and keyboard bezel and run the tool along the side until the cover is fully released.
    • Don't pull the front of the keyboard up very far. There is a small, potentially fragile ribbon cable on the back of the touchpad that is still attached to the system board.
    • Carefully flip the keyboard bezel over (toward you) to reveal the touchpad ribbon cable.
  11. HP Mini 110-1046NR Speakers Replacement: étape 11, image 1 de 3 HP Mini 110-1046NR Speakers Replacement: étape 11, image 2 de 3 HP Mini 110-1046NR Speakers Replacement: étape 11, image 3 de 3
    • Locate the black and white tab that connects the touchpad ribbon cable to the motherboard.
    • Using your fingernail or a pry stick, flip the white tab up to release the ribbon cable end.
    • Remove the touchpad ribbon cable from the receptacle on the system board by gently pulling the ribbon away from the clamp.
  12. HP Mini 110-1046NR Speakers Replacement, Speakers: étape 12, image 1 de 3 HP Mini 110-1046NR Speakers Replacement, Speakers: étape 12, image 2 de 3 HP Mini 110-1046NR Speakers Replacement, Speakers: étape 12, image 3 de 3
    • Remove the rubber capsule located on the upper left hand side above the fan.
    • Remove the two 3.8mm screws located on the power management board with a PH1 Philips head screw driver.
  13. HP Mini 110-1046NR Speakers Replacement: étape 13, image 1 de 3 HP Mini 110-1046NR Speakers Replacement: étape 13, image 2 de 3 HP Mini 110-1046NR Speakers Replacement: étape 13, image 3 de 3
    • Pull the power management board out of the way to allow access to the hinge screws as shown.
    • Remove the two 3.8mm screws that secure the left screen hinge using a PH1 screwdriver.
    • You may have to also hold a couple of wires out of the way to access the screws.
  14. HP Mini 110-1046NR Speakers Replacement: étape 14, image 1 de 3 HP Mini 110-1046NR Speakers Replacement: étape 14, image 2 de 3 HP Mini 110-1046NR Speakers Replacement: étape 14, image 3 de 3
    • Remove the two 3.8mm PH1 screws with a Philips Head screw driver holding the right screen bracket in place.
    • Again, wires may be blocking the accessibility to the screws, therefore you may need to move the wires around till you can access the screws.
    • While removing the last screw, hold the screen steady with one hand to avoid binding the last screw or letting the screen fall.
  15. HP Mini 110-1046NR Speakers Replacement: étape 15, image 1 de 3 HP Mini 110-1046NR Speakers Replacement: étape 15, image 2 de 3 HP Mini 110-1046NR Speakers Replacement: étape 15, image 3 de 3
    • Once the screen is disconnected from the frame of the computer, gently lay the top screen down.
    • The screen is connected by internal clips and adhesive, therefore some force will be required.
    • Use the spudger to pry the the screen bezel from the screen.
  16. HP Mini 110-1046NR Speakers Replacement: étape 16, image 1 de 3 HP Mini 110-1046NR Speakers Replacement: étape 16, image 2 de 3 HP Mini 110-1046NR Speakers Replacement: étape 16, image 3 de 3
    • Remove the three 2.9mm PH0 screws connecting the speakers to the screen lid.
    • Remove the two 2.9mm PH0 screws that hold the lid to the screen. This will allow you to extract the speaker wire from behind the hinge.
    • Locate the speaker wire and its receptacle on the system board. Push it directly out using your fingers.
    • Tape will be holding several wires in place, this tape will need to be removed in order to take the speakers completely out.
Jared Cooper
Membre depuis le 10/18/13
649 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 14-1, Benson Fall 2013 Membre de l'équipe Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,572
