Aller au contenu principal
HP Photosmart c3180 Feed Roller Replacement
Ce dont vous avez besoin
  1. HP Photosmart c3180 Feed Roller Replacement, Top Panel of HP Photosmart c3180 printer: étape 1, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement, Top Panel of HP Photosmart c3180 printer: étape 1, image 2 de 2
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. HP Photosmart c3180 Feed Roller Replacement: étape 2, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 2, image 2 de 2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. HP Photosmart c3180 Feed Roller Replacement: étape 3, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 3, image 2 de 2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. HP Photosmart c3180 Feed Roller Replacement: étape 4, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 4, image 2 de 2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. HP Photosmart c3180 Feed Roller Replacement: étape 5, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 5, image 2 de 2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. HP Photosmart c3180 Feed Roller Replacement: étape 6, image 1 de 1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. HP Photosmart c3180 Feed Roller Replacement: étape 7, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 7, image 2 de 2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
  8. HP Photosmart c3180 Feed Roller Replacement: étape 8, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 8, image 2 de 2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. HP Photosmart c3180 Feed Roller Replacement: étape 9, image 1 de 1
    • Carefully lift the top panel of the printer away from the printer body.
  10. HP Photosmart c3180 Feed Roller Replacement, Ink Cartridge Track: étape 10, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement, Ink Cartridge Track: étape 10, image 2 de 2
    • Set aside the top panel of the printer.
    • Remove the two T10 12 mm Torx screws from the top front of the printer
  11. HP Photosmart c3180 Feed Roller Replacement: étape 11, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 11, image 2 de 2
    • Rotate the Printer 90 degrees counter clockwise.
    • Remove the scanner cable from the main circuit board.
    • Grasp the bottom of the cable and pull straight up. Do not wiggle it from side to side or twist it as this can damage the connection.
  12. HP Photosmart c3180 Feed Roller Replacement: étape 12, image 1 de 1
    • Using both hands, lift the scanner tray from the body of the printer.
  13. HP Photosmart c3180 Feed Roller Replacement: étape 13, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 13, image 2 de 2
    • Remove the power button circuit board from the support frame by pinching the left side, and pulling forward and to the left simultaneously.
    • Push up on the tab holding the secondary control circuit board with the spudger and pull it forward to remove it.
    • Be careful not to pull too hard on the cable connecting the power button control circuit board and the secondary control circuit board to the main circuit board
  14. HP Photosmart c3180 Feed Roller Replacement: étape 14, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 14, image 2 de 2
    • Lift the support frame off of the printer body with both hands.
  15. HP Photosmart c3180 Feed Roller Replacement: étape 15, image 1 de 1
    • Remove the printer door and paper tray by putting them in the closed position and not laying flat then rotating them upwards lift the left side up.
  16. HP Photosmart c3180 Feed Roller Replacement: étape 16, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 16, image 2 de 2
    • Remove both of the ink cartridges by grabbing the front of the ink cartridge and pulling down.
    • Make sure that the printer carriage is pushed all the way to the right.
  17. HP Photosmart c3180 Feed Roller Replacement: étape 17, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 17, image 2 de 2
    • Remove the T10 6 mm Torx screw on the left side of the track assembly.
    • Remove the T10 12 mm Torx screw on the left side of the track assembly.
  18. HP Photosmart c3180 Feed Roller Replacement: étape 18, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 18, image 2 de 2
    • Gently push the ink cartridge carriage to the left side of the printer.
  19. HP Photosmart c3180 Feed Roller Replacement: étape 19, image 1 de 1
    • Remove the two T10 6 mm Torx screws.
  20. HP Photosmart c3180 Feed Roller Replacement: étape 20, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 20, image 2 de 2
    • Remove the cable connecting the ink cartridge carriage to the main circuit board.
    • Pull straight up to free the cable from the main circuit board. Do not twist or wiggle the cable as doing so can damage it.
    • You may need to lift the carriage up with one hand in order to reach the cable with the free hand as shown.
  21. HP Photosmart c3180 Feed Roller Replacement: étape 21, image 1 de 1
    • Carefully remove the connector holding the drive motor wires to the main circuit board.
  22. HP Photosmart c3180 Feed Roller Replacement: étape 22, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 22, image 2 de 2
    • Slide the ink cartridge carriage all the way to the right side of the printer.
    • Using both hands, carefully lift the ink cartridge track off of the main body of the printer.
  23. HP Photosmart c3180 Feed Roller Replacement, Feed Roller Assembly: étape 23, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement, Feed Roller Assembly: étape 23, image 2 de 2
    • Set aside the ink cartridge carriage.
    • Remove the three T10 12mm Torx screws holding the paper guide to the printer body.
    • Lift the paper guide directly up to remove it and set it aside.
  24. HP Photosmart c3180 Feed Roller Replacement: étape 24, image 1 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 24, image 2 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 24, image 3 de 3
    • Remove the five T10 12mm Torx screws from the roller holder.
    • 5th screw is located in deeper crevice.
  25. HP Photosmart c3180 Feed Roller Replacement: étape 25, image 1 de 1
    • Remove the plastic gear cover by pulling it away from the printer body and lifting it up.
  26. HP Photosmart c3180 Feed Roller Replacement: étape 26, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 26, image 2 de 2
    • Remove the metal tab by rotating it away from the body of the printer and pulling up.
    • Remove the brush by grasping it firmly by the base and lift straight up.
  27. HP Photosmart c3180 Feed Roller Replacement: étape 27, image 1 de 1
    • Remove the pad holder by lifting it straight up.
  28. HP Photosmart c3180 Feed Roller Replacement: étape 28, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 28, image 2 de 2
    • Remove the connector holding the feed roller motor to the logic board by pulling it strait up
    • Remove the T10 12mm Torx screw on the roller panel.
  29. HP Photosmart c3180 Feed Roller Replacement: étape 29, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 29, image 2 de 2
    • Disconnect the page sensor from the logic board by pulling straight up on the connector.
  30. HP Photosmart c3180 Feed Roller Replacement: étape 30, image 1 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 30, image 2 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 30, image 3 de 3
    • Rotate the printer 180 degrees and turn it up on to the front side, so that the back of the printer is facing up and the bottom facing you.
    • Be careful because the feed roller assembly is now loose, but it is still attached to the main body of the printer.
    • Push in the tab on the left side of the back panel and pull outward to remove the back panel.
  31. HP Photosmart c3180 Feed Roller Replacement: étape 31, image 1 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 31, image 2 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 31, image 3 de 3
    • Tilt the printer up until the bottom of the printer can be seen.
    • Remove the T10 12mm Torx screw from the bottom panel.
    • Grasp the top edge of the bottom panel and pull to remove it.
  32. HP Photosmart c3180 Feed Roller Replacement: étape 32, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement: étape 32, image 2 de 2
    • Remove the black plastic cross member from the bottom of the printer.
  33. HP Photosmart c3180 Feed Roller Replacement: étape 33, image 1 de 1
    • Turn the printer back down so that it is sitting on the bottom panel and rotate the printer 180 degrees.
  34. HP Photosmart c3180 Feed Roller Replacement: étape 34, image 1 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 34, image 2 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 34, image 3 de 3
    • Remove the printer head cleaner by lifting the front of the printer head cleaner above the track and slide it forward.
    • This is an extremely difficult step. It can take quite a bit of force to lift the printer head cleaner above the track and it is easy to slip and hurt yourself.
  35. HP Photosmart c3180 Feed Roller Replacement: étape 35, image 1 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 35, image 2 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 35, image 3 de 3
    • This step can be performed with out rotating the printer, but we have rotated the printer for clarity.
    • Grasp the left side of the feed roller assembly and pull towards the front of the printer and up to free the metal tab from the slot.
  36. HP Photosmart c3180 Feed Roller Replacement: étape 36, image 1 de 1
    • Lift the feed roller assembly straight up to remove it.
  37. HP Photosmart c3180 Feed Roller Replacement, Feed Roller: étape 37, image 1 de 2 HP Photosmart c3180 Feed Roller Replacement, Feed Roller: étape 37, image 2 de 2
    • Set aside the printer base.
    • Flip the feed roller assembly over so that its bottom and so that the feed roller is on the left side.
  38. HP Photosmart c3180 Feed Roller Replacement: étape 38, image 1 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 38, image 2 de 3 HP Photosmart c3180 Feed Roller Replacement: étape 38, image 3 de 3
    • Remove the T10 12mm screw holding the feed roller in place.
    • Carefully pull apart the two plastic beams to free the feed roller and lift the feed roller out of the assemblage.
8 autres ont terminé cette réparation.
Jim
Membre depuis le 10/06/11
1 590 Réputation
10 tutoriels rédigés
Équipe
Cal Poly, Team 20-30, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 membres
25 tutoriels rédigés
Un commentaire
Does the encoder wheel gear have to be exactly in a certain position, or does it not matter?
Juraj Angelovic - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 33
Total : 9,793
