Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP ProBook 640 G2 Battery Replacement
Ce dont vous avez besoin
  1. HP ProBook 640 G2 Battery Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop so the bottom is facing up.
    • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
    • Use a Torx T9 screwdriver to remove the single 6 mm screw.
  2. HP ProBook 640 G2 Battery Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to carefully pry the bottom case.
    • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
    • Remove the bottom cover.
  3. HP ProBook 640 G2 Battery Replacement: étape 3, image 1 de 3 HP ProBook 640 G2 Battery Replacement: étape 3, image 2 de 3 HP ProBook 640 G2 Battery Replacement: étape 3, image 3 de 3
    • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
    • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
Note - Be sure to dispose of your old battery responsibly! Check out iFixit's Guide on Recycling E-waste.
For optimal performance, calibrate your newly installed battery after completing this guide.
SarahTrachsel
Membre depuis le 09/12/25
196 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 33
Total : 205
