Introduction
Are you are having problems with your HP Stream 11-y010nr battery? Is the battery life bad enough that it needs to be replaced? The first thing that you should do is see our troubleshooting page and check it before the battery gets replaced. HP Stream 11-y010nr Troubleshooting
This guide will take you through the necessary steps to properly remove and replace the battery. Use caution when taking the battery out as it can catch on fire if the battery pack is punctured. Additionally, a thin wire is attached to the bottom of the battery so use caution when taking it out.
Prior to beginning, ensure the laptop is completely powered off such that it will not interfere with the steps in this guide.
Ce dont vous avez besoin
Use your fingers or a spudger to pull the battery cable out from its connector.
