Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP ZBook 15 Hard Drive Replacement
Ce dont vous avez besoin
  1. HP ZBook 15 Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP ZBook 15 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
    Demander à FixBot
    Ajouter un commentaire
  2. HP ZBook 15 Hard Drive Replacement, Back Cover: étape 2, image 1 de 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
    Demander à FixBot
  3. HP ZBook 15 Hard Drive Replacement, HP ZBook 15 Hard Drive Disassembly: étape 3, image 1 de 1
    • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
    • The screws will remain inside the springs of the hard drive caddy cover.
    Demander à FixBot
  4. HP ZBook 15 Hard Drive Replacement: étape 4, image 1 de 2 HP ZBook 15 Hard Drive Replacement: étape 4, image 2 de 2
    • Pull the green tab away from the metal casing and lift the drive out.
    Demander à FixBot
  5. HP ZBook 15 Hard Drive Replacement, Hard Drive: étape 5, image 1 de 1
    • Remove the two 3mm screws on either side of the device with a Phillips #0 screwdriver to remove the drive caddy.
    Demander à FixBot
13 autres ont terminé cette réparation.
Grant Terris
Membre depuis le 01/30/15
2 888 Réputation
12 tutoriels rédigés
Équipe
Cal Poly, Team 8-43, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 membres
19 tutoriels rédigés
3 commentaires de tutoriel
You can use Macrium Reflect (there's a free non-commercial version) to backup your disk to an external drive before swapping the drive.
Paul M - Réponse Partager
There is written 'SSD' on its cover, and I'm confused now. Actually I need to disconnect the HDD and then install new OS on the SSD, and now I'm not sure if the drive that you just removed is SSD or HDD because on mine it say SSD. Please help me out.
Sajid - Réponse Partager
how hard disk i can buy for my zbook 15?
thanks
francesco perego - Réponse Partager
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 44
30 derniers jours : 149
Total : 31,624
