Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
  • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
Ajouter un commentaire
Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
  • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
  • Remove the lower speaker cover.
Remove the screw under the speaker cover using a T6 Torx screwdriver. Remove the screw under the speaker cover using a T6 Torx screwdriver. Remove the screw under the speaker cover using a T6 Torx screwdriver.
  • Remove the screw under the speaker cover using a T6 Torx screwdriver.
Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone. Carefully work your way up each side of the display and separate the rear case. There are three clips on each side. Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
  • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
  • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
Remove the rear case from the phone. Remove the rear case from the phone.
  • Remove the rear case from the phone.
3 autre(s) ont terminé cette réparation.
Chris Jose
Membre depuis le 22/09/2014
671 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 48
Total : 6,442
