Aller au contenu principal
HTC Vive Cosmos Lens and LCD Frame Replacement
Ce dont vous avez besoin
  1. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the facerest: étape 1, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the facerest: étape 1, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the facerest: étape 1, image 3 de 3
    • Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
    • With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
  2. HTC Vive Cosmos Lens and LCD Frame Replacement, Release the faceplate switch: étape 2, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Release the faceplate switch: étape 2, image 2 de 2
    • Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
  3. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the faceplate: étape 3, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the faceplate: étape 3, image 2 de 2
    • While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
    • Remove the faceplate.
  4. HTC Vive Cosmos Lens and LCD Frame Replacement, Unscrew the focus knob: étape 4, image 1 de 1
    • Use a T5 Torx driver to remove the 4.1 mm long screw securing the focus knob.
  5. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the focus knob: étape 5, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the focus knob: étape 5, image 2 de 2
    • Slide the focus knob out of the plastic housing, off of the focus rod, and remove it.
  6. HTC Vive Cosmos Lens and LCD Frame Replacement, Unplug the audio connector: étape 6, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Unplug the audio connector: étape 6, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Unplug the audio connector: étape 6, image 3 de 3
    • Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
    • Lift the audio connector straight up to unplug it.
  7. HTC Vive Cosmos Lens and LCD Frame Replacement, Unscrew the LCD and motherboard assembly: étape 7, image 1 de 1
    • Use a T5 Torx driver to remove the three 4.1 mm long screws securing the LCD and motherboard assembly.
  8. HTC Vive Cosmos Lens and LCD Frame Replacement: étape 8, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 8, image 2 de 2
    • Gently peel up the stickers on either side of the front of the Vive. If possible, keep the stickers intact and reuse them.
  9. HTC Vive Cosmos Lens and LCD Frame Replacement: étape 9, image 1 de 1
    • Use a T5 Torx driver to unscrew the screws securing the upper component cover and the LCD and motherboard assembly:
    • Sixteen 4.1 mm long screws
    • One captive screw
    • This screw is covered by a sticker. Poke your driver through the sticker to access the screw.
    • Two 4.1 mm long screws
    • These screws are covered by stickers. Poke your driver through the stickers to access the screws.
  10. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the microphone: étape 10, image 1 de 1
    • Remove the microphone cover from the bottom edge of the headset.
  11. HTC Vive Cosmos Lens and LCD Frame Replacement, Separate the microphone adhesive: étape 11, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Separate the microphone adhesive: étape 11, image 2 de 2
    • Slide an opening pick under the microphone to separate the adhesive securing it to the Vive.
    • If this is difficult, use a heated iOpener, hair dryer, or heat gun to apply heat to adhesive.
  12. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the upper component cover: étape 12, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the upper component cover: étape 12, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the upper component cover: étape 12, image 3 de 3
    • Angle the bottom end of the upper component cover away from the front of the Vive.
    • Pull the upper component cover away from the front of the Vive and remove it.
  13. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the camera connector covers: étape 13, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the camera connector covers: étape 13, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the camera connector covers: étape 13, image 3 de 3
    • Slide the camera connector covers on either side of the LCD and motherboard assembly away from the center off of the assembly and remove them.
  14. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the cameras: étape 14, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the cameras: étape 14, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the cameras: étape 14, image 3 de 3
    • Peel the tape over the right camera connector back enough to access the camera's ZIF connector underneath.
    • Repeat the same process to peel back the tape over the left camera ZIF connector.
  15. HTC Vive Cosmos Lens and LCD Frame Replacement: étape 15, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 15, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 15, image 3 de 3
    • Use the point of a spudger to flip up the small locking flap securing the right camera cable ZIF connector.
    • Carefully slide the camera connector cable straight out of its socket on the motherboard.
  16. HTC Vive Cosmos Lens and LCD Frame Replacement: étape 16, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 16, image 2 de 2
    • Use the point of a spudger to flip up the small locking flap securing the left camera cable ZIF connector.
  17. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the microphone: étape 17, image 1 de 1
    • Peel the yellow tape off of the microphone connector.
  18. HTC Vive Cosmos Lens and LCD Frame Replacement: étape 18, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 18, image 2 de 2
    • Use the point of a spudger to flip up the small locking flap securing the microphone cable ZIF connector.
  19. HTC Vive Cosmos Lens and LCD Frame Replacement: étape 19, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 19, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 19, image 3 de 3
    • Carefully slide the microphone connector cable straight out of its socket on the motherboard.
    • With the cable out of its socket, slide the cable toward the bottom of the Vive and out of its clip on the LCD and motherboard assembly.
    • Take care not to crease or tear the cable while you're moving it.
  20. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD and motherboard assembly: étape 20, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD and motherboard assembly: étape 20, image 2 de 2
    • Lift the LCD and motherboard assembly out of the headset.
    • The assembly is secured by clips around the edges. It may help to release the clips using a thin plastic tool, like an opening tool or a spudger.
  21. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the LCD panels: étape 21, image 1 de 1
    • Use a T5 Torx driver to remove the four 2.9 mm long screws securing the LCD connectors.
  22. HTC Vive Cosmos Lens and LCD Frame Replacement: étape 22, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 22, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 22, image 3 de 3
    • Use the flat end of a spudger to pry the LCD connectors straight up and out of their sockets on the daughterboard.
  23. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD frame assembly: étape 23, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD frame assembly: étape 23, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD frame assembly: étape 23, image 3 de 3
    • Gently pull the bottom edge of the midframe away from the bottom edges of the LCD frames to unclip the LCD frames from the midframe.
  24. HTC Vive Cosmos Lens and LCD Frame Replacement: étape 24, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 24, image 2 de 2
    • Remove the LCD frame assembly from the midframe.
    • During reassembly, first seat the support rod in its slots in the midframe. Then gently press the rest of the LCD frame assembly into the midframe so that the bottom edges of the LCD frames clip into the midframe.
  25. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the eyepiece gasket: étape 25, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the eyepiece gasket: étape 25, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the eyepiece gasket: étape 25, image 3 de 3
    • Gently lift the eyepiece gasket off of the lens and LCD frames to remove it.
  26. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the support rod: étape 26, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the support rod: étape 26, image 2 de 2
    • Slide the support rod out of its brackets on the lens and LCD frames.
  27. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the focus rod: étape 27, image 1 de 1
    • Use a T5 Torx driver to remove the four 4.1 mm screws securing the focus rod brackets.
  28. HTC Vive Cosmos Lens and LCD Frame Replacement: étape 28, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 28, image 2 de 2
    • Remove the focus rod and its brackets.
  29. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the outer LCD cover: étape 29, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the outer LCD cover: étape 29, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the outer LCD cover: étape 29, image 3 de 3
    • Pick one lens and LCD frame to work with for the rest of the guide. After removing the first frame, repeat the next seven steps with the other frame to remove it as well.
    • Insert the flat end of a spudger in between the edge of the lens LCD frame and the outer LCD cover.
    • Twist the spudger to release the clips securing the LCD cover to the frame.
    • Repeat the insertion and twisting process for each clip on the LCD cover.
  30. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the LCD panel: étape 30, image 1 de 1
    • Gently peel the sticker covering the LCD cable and connector back far enough to access the LCD connector.
  31. HTC Vive Cosmos Lens and LCD Frame Replacement: étape 31, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 31, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement: étape 31, image 3 de 3
    • Use the flat end of a spudger to flip up the locking flap securing the LCD cable ZIF connector.
    • Carefully slide the LCD cable straight out of its socket.
  32. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the inner LCD cover: étape 32, image 1 de 2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the inner LCD cover: étape 32, image 2 de 2
    • Slowly lift the LCD cover away from the lens and LCD frame, taking care to thread the LCD cable through the cover.
  33. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD panel: étape 33, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD panel: étape 33, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD panel: étape 33, image 3 de 3
    • This step may damage the LCD panel. Continue only if the panel is already damaged.
    • Use the flat end of a spudger to pry up the LCD panel.
    • Remove the LCD panel.
  34. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens: étape 34, image 1 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens: étape 34, image 2 de 3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens: étape 34, image 3 de 3
    • Push against the back of the lens to remove it from the frame.
    • If this is difficult, try heating the lens to soften the adhesive holding it to the frame.
  35. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens and LCD frame: étape 35, image 1 de 1
    • Only the lens and LCD frame remains.
    • Repeat the last seven steps with the other lens and LCD frame to remove it as well.
Adam O'Camb
Membre depuis le 04/11/15
196 940 Réputation
416 tutoriels rédigés
2 commentaires
Good guide, it's not too hard it's just really tedious and annoying, I think I managed to finish the repair within an hour. The main annoying part is the mic and reconnecting the ribbon cable.
Josh (BeigeAnimal) - Réponse
Would this process work on the Cosmos Elite as well?
Wickednoreaster - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 1,186
