Aller au contenu principal
HTC Vive Focus Facerest Replacement
Ce dont vous avez besoin
  1. HTC Vive Focus Facerest Replacement, Remove the facerest cushion: étape 1, image 1 de 3 HTC Vive Focus Facerest Replacement, Remove the facerest cushion: étape 1, image 2 de 3 HTC Vive Focus Facerest Replacement, Remove the facerest cushion: étape 1, image 3 de 3
    • Place your device upside-down on your work surface.
    • The facerest cushion is lightly held into place by seven plastic clips.
    • Use your fingers to gently pull the facerest cushion straight off of the facerest to remove it.
  2. HTC Vive Focus Facerest Replacement, Remove the facerest: étape 2, image 1 de 1
    • Use a T5 Torx screwdriver to remove the eight 4.5 mm screws securing the facerest.
    • One of the screws will be covered by a tamper-evident sticker. Press the driver through the sticker to remove the screw.
  3. HTC Vive Focus Facerest Replacement: étape 3, image 1 de 3 HTC Vive Focus Facerest Replacement: étape 3, image 2 de 3 HTC Vive Focus Facerest Replacement: étape 3, image 3 de 3
    • Insert an opening pick into the upper-left corner of the facerest.
    • Twist the opening pick to release the plastic clip securing the facerest.
    • Repeat for the upper-right corner.
    • Don't remove the facerest yet. It's still attached by the facerest sensor ribbon cable.
  4. HTC Vive Focus Facerest Replacement, Remove the facerest sensor: étape 4, image 1 de 3 HTC Vive Focus Facerest Replacement, Remove the facerest sensor: étape 4, image 2 de 3 HTC Vive Focus Facerest Replacement, Remove the facerest sensor: étape 4, image 3 de 3
    • Carefully flip your device over.
    • Pull the facerest out just enough to access the screws securing the facerest sensor.
    • Don't put any strain on the facerest sensor ribbon cable.
    • During reassembly, make sure the facerest sensor ribbon cable is positioned between the lenses before reinstalling the facerest.
  5. HTC Vive Focus Facerest Replacement: étape 5, image 1 de 1
    • Use a T5 Torx screwdriver to remove the two 2.4 mm screws securing the facerest sensor to the facerest.
  6. HTC Vive Focus Facerest Replacement: étape 6, image 1 de 1
    • Remove the facerest.
Sam Omiotek
Membre depuis le 02/25/19
73 693 Réputation
288 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 11
Total : 94
