Aller au contenu principal
HTC Vive Focus Front Cover Replacement
Ce dont vous avez besoin
  1. HTC Vive Focus Front Cover Replacement, Remove the facerest cushion: étape 1, image 1 de 3 HTC Vive Focus Front Cover Replacement, Remove the facerest cushion: étape 1, image 2 de 3 HTC Vive Focus Front Cover Replacement, Remove the facerest cushion: étape 1, image 3 de 3
    • Place your device upside-down on your work surface.
    • The facerest cushion is lightly held into place by seven plastic clips.
    • Use your fingers to gently pull the facerest cushion straight off of the facerest to remove it.
  2. HTC Vive Focus Front Cover Replacement, Remove the facerest: étape 2, image 1 de 1
    • Use a T5 Torx screwdriver to remove the eight 4.5 mm screws securing the facerest.
    • One of the screws will be covered by a tamper-evident sticker. Press the driver through the sticker to remove the screw.
  3. HTC Vive Focus Front Cover Replacement: étape 3, image 1 de 3 HTC Vive Focus Front Cover Replacement: étape 3, image 2 de 3 HTC Vive Focus Front Cover Replacement: étape 3, image 3 de 3
    • Insert an opening pick into the upper-left corner of the facerest.
    • Twist the opening pick to release the plastic clip securing the facerest.
    • Repeat for the upper-right corner.
    • Don't remove the facerest yet. It's still attached by the facerest sensor ribbon cable.
  4. HTC Vive Focus Front Cover Replacement, Remove the facerest sensor: étape 4, image 1 de 3 HTC Vive Focus Front Cover Replacement, Remove the facerest sensor: étape 4, image 2 de 3 HTC Vive Focus Front Cover Replacement, Remove the facerest sensor: étape 4, image 3 de 3
    • Carefully flip your device over.
    • Pull the facerest out just enough to access the screws securing the facerest sensor.
    • Don't put any strain on the facerest sensor ribbon cable.
    • During reassembly, make sure the facerest sensor ribbon cable is positioned between the lenses before reinstalling the facerest.
  5. HTC Vive Focus Front Cover Replacement: étape 5, image 1 de 1
    • Use a T5 Torx screwdriver to remove the two 2.4 mm screws securing the facerest sensor to the facerest.
  6. HTC Vive Focus Front Cover Replacement: étape 6, image 1 de 1
    • Remove the facerest.
  7. HTC Vive Focus Front Cover Replacement, Unscrew the front cover: étape 7, image 1 de 2 HTC Vive Focus Front Cover Replacement, Unscrew the front cover: étape 7, image 2 de 2
    • Use your fingers to slide the lenses towards each other so that they are positioned towards the center of the device.
  8. HTC Vive Focus Front Cover Replacement: étape 8, image 1 de 2 HTC Vive Focus Front Cover Replacement: étape 8, image 2 de 2
    • Use a T5 Torx screwdriver to remove the four screws securing the front cover from inside the device:
    • Two 5.7 mm screws with fine threads
    • Two 5.5 mm screws with coarse threads
    • The coarse-thread screws can strip easily. During reassembly, tighten the coarse-thread screws until they're hand tight and then no more.
  9. HTC Vive Focus Front Cover Replacement, Remove the front cover: étape 9, image 1 de 2 HTC Vive Focus Front Cover Replacement, Remove the front cover: étape 9, image 2 de 2
    • Note the location of the plastic welds on both vertical edges of the front cover.
    • After reassembly, the gap between the front cover and the side panels may no longer be flush. This is a cosmetic defect only and will not affect operation. The front cover's clips and screws are sufficient to secure it to the rest of the device.
  10. HTC Vive Focus Front Cover Replacement: étape 10, image 1 de 3 HTC Vive Focus Front Cover Replacement: étape 10, image 2 de 3 HTC Vive Focus Front Cover Replacement: étape 10, image 3 de 3
    • Insert an opening pick into the top of the front cover near the upper left corner.
    • Slide the opening pick around the upper left corner of the front cover.
  11. HTC Vive Focus Front Cover Replacement: étape 11, image 1 de 2 HTC Vive Focus Front Cover Replacement: étape 11, image 2 de 2
    • Use the opening pick to separate the weld securing the left side vertical edge of the front cover.
    • The weld may require significant force to separate.
  12. HTC Vive Focus Front Cover Replacement: étape 12, image 1 de 3 HTC Vive Focus Front Cover Replacement: étape 12, image 2 de 3 HTC Vive Focus Front Cover Replacement: étape 12, image 3 de 3
    • Insert an opening pick into the top of the front cover near the upper right corner.
    • Slide the opening pick around the upper right corner of the front cover.
  13. HTC Vive Focus Front Cover Replacement: étape 13, image 1 de 2 HTC Vive Focus Front Cover Replacement: étape 13, image 2 de 2
    • Use the opening pick to separate the weld securing the right side vertical edge of the front cover.
  14. HTC Vive Focus Front Cover Replacement: étape 14, image 1 de 3 HTC Vive Focus Front Cover Replacement: étape 14, image 2 de 3 HTC Vive Focus Front Cover Replacement: étape 14, image 3 de 3
    • Flip the device upside-down.
    • Use an opening pick to disconnect the plastic clips securing the bottom right edge of the front cover to the device.
  15. HTC Vive Focus Front Cover Replacement: étape 15, image 1 de 2 HTC Vive Focus Front Cover Replacement: étape 15, image 2 de 2
    • Slide the opening pick along the bottom edge of the front cover to separate it from the device.
  16. HTC Vive Focus Front Cover Replacement: étape 16, image 1 de 2 HTC Vive Focus Front Cover Replacement: étape 16, image 2 de 2
    • Use the opening pick to disconnect the plastic clips securing the bottom-left edge of the front cover to the device.
  17. HTC Vive Focus Front Cover Replacement: étape 17, image 1 de 2 HTC Vive Focus Front Cover Replacement: étape 17, image 2 de 2
    • Flip the device right-side up.
    • Use the opening pick to separate the last few plastic clips securing the top of the front cover.
  18. HTC Vive Focus Front Cover Replacement: étape 18, image 1 de 2 HTC Vive Focus Front Cover Replacement: étape 18, image 2 de 2
    • Remove the front cover.
Sam Omiotek
Membre depuis le 02/25/19
73 693 Réputation
288 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 7
Total : 135
