Aller au contenu principal
HTC Vive Focus Knob Replacement
Ce dont vous avez besoin
  1. HTC Vive Focus Knob Replacement, Unscrew the outer shell: étape 1, image 1 de 3 HTC Vive Focus Knob Replacement, Unscrew the outer shell: étape 1, image 2 de 3 HTC Vive Focus Knob Replacement, Unscrew the outer shell: étape 1, image 3 de 3
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
  2. HTC Vive Focus Knob Replacement, Remove the outer shell: étape 2, image 1 de 2 HTC Vive Focus Knob Replacement, Remove the outer shell: étape 2, image 2 de 2
    • Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
  3. HTC Vive Focus Knob Replacement: étape 3, image 1 de 2 HTC Vive Focus Knob Replacement: étape 3, image 2 de 2
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset until you feel the clips on the front of the cover release.
    • If the shell is difficult to remove, try prying along the seam with the flat end of a spudger to release the clips.
  4. HTC Vive Focus Knob Replacement: étape 4, image 1 de 2 HTC Vive Focus Knob Replacement: étape 4, image 2 de 2
    • Slide the right side of the outer shell to the right and off of the headset.
  5. HTC Vive Focus Knob Replacement: étape 5, image 1 de 2 HTC Vive Focus Knob Replacement: étape 5, image 2 de 2
    • Repeat the last three steps for the left side of the outer shell and remove it.
  6. HTC Vive Focus Knob Replacement, Unscrew the focus knob: étape 6, image 1 de 1
    • Use a PH000 driver to remove the screw securing the focus knob.
  7. HTC Vive Focus Knob Replacement, Remove the focus knob: étape 7, image 1 de 2 HTC Vive Focus Knob Replacement, Remove the focus knob: étape 7, image 2 de 2
    • Slide the focus knob off of the focus rod and remove it.
Adam O'Camb
Membre depuis le 04/11/15
196 626 Réputation
416 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,364
