Introduction
Use this guide to replace the loudspeaker in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
Ce dont vous avez besoin
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Remove the Phillips #00 screw.
Use tweezers to remove the metal plate.
Use a spudger to disconnect the battery flex cable.
Remove the four Phillips #00 screws.
Use Tweezers to remove the metal plate.
Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can use an iOpener to loosen it.
Remove the loudspeaker.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
2 autres ont terminé cette réparation.
