Aller au contenu principal
Jabra CRUISER2 Speaker Replacement
Ce dont vous avez besoin
  1. Jabra CRUISER2 Speaker Replacement, Front Plate: étape 1, image 1 de 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • Instructions iOpener
  2. Jabra CRUISER2 Speaker Replacement: étape 2, image 1 de 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Speaker Replacement: étape 3, image 1 de 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Speaker Replacement, Speaker: étape 4, image 1 de 2 Jabra CRUISER2 Speaker Replacement, Speaker: étape 4, image 2 de 2
    • Carefully unplug the red and black wires that run from the speaker to the motherboard by detaching the white connecting piece.
  5. Jabra CRUISER2 Speaker Replacement: étape 5, image 1 de 1
    • Using the PH000, unscrew the two 5.5mm screws attaching the speaker to the front plate.
    • The screwdriver sizes are located on the sides of their heads.
  6. Jabra CRUISER2 Speaker Replacement: étape 6, image 1 de 1
    • Gently pull the black and red wires away from the back plate to remove the speaker.
  7. Jabra CRUISER2 Speaker Replacement: étape 7, image 1 de 2 Jabra CRUISER2 Speaker Replacement: étape 7, image 2 de 2
    • Carefully pull the wires away from the speaker, detaching them from the adhesive, while keeping the ends intact.
Spartacus
Membre depuis le 10/17/14
636 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team 8-13, Williams Fall 2014 Membre de l'équipe Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 membres
5 tutoriels rédigés
5 commentaires
Is this a fairly standard speaker? With radio shack dead, can you suggest a source? Any specs? Yhanks
Brucereno2 - Réponse
Did you ever find a speaker for your jabra cruiser?
Scot Tetreault -
halo
where i can get the new speaker for jabra cruiser 2?
Frantisek Fridrich - Réponse
simple speaker in electronic parts shop 8ohm diameter 35mm price 1.2 €
A 36 mm speaker will also fit nicely. A 1 watt 8 ohms speaker is the best choice - the amplifier is not able to output enough power to drive a 2+ watt speaker.
Mobi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 10
Total : 1,861
