Aller au contenu principal
Kindle Fire HDX 7" Volume Button Replacement
Ce dont vous avez besoin
  1. Kindle Fire HDX 7" Volume Button Replacement, Speaker Bezel: étape 1, image 1 de 3 Kindle Fire HDX 7" Volume Button Replacement, Speaker Bezel: étape 1, image 2 de 3 Kindle Fire HDX 7" Volume Button Replacement, Speaker Bezel: étape 1, image 3 de 3
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Volume Button Replacement: étape 2, image 1 de 1
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Volume Button Replacement, Rear Panel: étape 3, image 1 de 1
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Volume Button Replacement: étape 4, image 1 de 2 Kindle Fire HDX 7" Volume Button Replacement: étape 4, image 2 de 2
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Volume Button Replacement: étape 5, image 1 de 1
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Volume Button Replacement, Volume Button: étape 7, image 1 de 1
    • Remove the two 2.1mm T5 Torx screws from the volume button retaining bracket.
  7. Kindle Fire HDX 7" Volume Button Replacement: étape 8, image 1 de 2 Kindle Fire HDX 7" Volume Button Replacement: étape 8, image 2 de 2
    • Pry up the volume button ribbon cable from the rear panel with the flat end of a spudger.
    • Pull up on the volume button ribbon cable to remove it from the tablet.
  8. Kindle Fire HDX 7" Volume Button Replacement: étape 9, image 1 de 1
    • Remove the volume button from the rear panel.
Blake Klein
Membre depuis le 01/29/17
70 568 Réputation
50 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 25
Total : 1,652
