Aller au contenu principal
Lenovo IdeaPad Flex 4-1470 Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Lower Case: étape 1, image 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Battery Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Battery Replacement: étape 2, image 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: étape 3, image 1 de 2 Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Battery Replacement: étape 4, image 1 de 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Battery Replacement: étape 5, image 1 de 1
    • Lift the battery up and out of the laptop.
9 autres ont terminé cette réparation.
Demario Robinson
Membre depuis le 10/02/17
1 038 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 membres
10 tutoriels rédigés
2 commentaires
thank for sharing this! I want to check if it is easy to swap HDD/SSD?
pama - Réponse
I'm grateful for the individuals who take time to share their knowledge. I'm 63yrs young with no technical skills. I followed your step by step instructions and was successful in changing my laptop battery. THANK YOU! 👩‍🦳👍
iamelara - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 33
Total : 13,864
