Introduction
The purpose of this guide is to demonstrate how to replace the battery of your Lenovo Ideapad 350-15IAP. This replacement guide is very simple and requires very little technical knowledge to complete. In summary, you will be using a Phillip’s head screwdriver to remove the case of the laptop. The battery will be immediately exposed and can be removed by simply removing four screws.
Ce dont vous avez besoin
Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
For optimal performance, after completing this guide, calibrate your newly installed battery.
