Aller au contenu principal
Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement
Ce dont vous avez besoin
  1. Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Back cover removal: étape 1, image 1 de 2 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Back cover removal: étape 1, image 2 de 2
    • Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
    • Six 12.7 mm PH00 screws
    • Four 4.2 mm PH00 screws
  2. Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the front clips: étape 2, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the front clips: étape 2, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the front clips: étape 2, image 3 de 3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
  3. Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement: étape 3, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement: étape 3, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement: étape 3, image 3 de 3
    • Angle the pick to about 45˚.
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the right clips: étape 4, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the right clips: étape 4, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the right clips: étape 4, image 3 de 3
    • Insert the rounded edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the right edge until you reach the plastic vents on the side.
  5. Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the left clips: étape 5, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the left clips: étape 5, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the left clips: étape 5, image 3 de 3
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the right vent clips: étape 6, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the right vent clips: étape 6, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the right vent clips: étape 6, image 3 de 3
    • Position the laptop vertically so you can easily access the plastic vents.
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the right side near the USB-A port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
  7. Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement: étape 7, image 1 de 2 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement: étape 7, image 2 de 2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the left vent clips: étape 8, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the left vent clips: étape 8, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Release the left vent clips: étape 8, image 3 de 3
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
  9. Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement: étape 9, image 1 de 2 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement: étape 9, image 2 de 2
  10. Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Remove the back cover: étape 10, image 1 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Remove the back cover: étape 10, image 2 de 3 Lenovo Legion 5 Pro 16ACH6H Back Cover Replacement, Remove the back cover: étape 10, image 3 de 3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
5 autres ont terminé cette réparation.
Chayton Ritter
Membre depuis le 08/21/20
19 094 Réputation
103 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
8 membres
8 054 tutoriels rédigés
3 commentaires
Great guide Chayton. I broke one of the clips when I took the legion 5 pro back panel off. I wish I had read your guide sooner!
Francis - Réponse
do you know wher can i find the replacement parts? i saw on aliexpress but i dont know if they are trustable.
Emme Tti - Réponse
Wish I read this guide before I did mine, got it done with a lot more hassle. Would love to see advice on what to use if you don't have an opening pick (a guy on YT had a guitar pick, I just used an old credit card and it was very difficult).
Martin Paluoja - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 84
30 derniers jours : 321
Total : 7,326
