Aller au contenu principal
Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the back cover: étape 1, image 1 de 2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the back cover: étape 1, image 2 de 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to loosen the five captive screws holding the back cover.
  2. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the corner clips: étape 2, image 1 de 2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the corner clips: étape 2, image 2 de 2
    • Insert an opening pick between a corner of the back cover and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when clips release.
    • Repeat this process for the opposite corner.
  3. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the edge clips: étape 3, image 1 de 2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the edge clips: étape 3, image 2 de 2
    • Insert the opening pick between the cover and the body.
    • Pry upward and release all of the retaining clips.
  4. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the back cover: étape 4, image 1 de 2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the back cover: étape 4, image 2 de 2
    • Lift the back cover off the chassis and remove it.
    • If the cover feels stuck to the chassis, use an opening pick to release any remaining clips around the perimeter of the back cover.
  5. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the battery: étape 5, image 1 de 2 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the battery: étape 5, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the six 4.9 mm screws securing the battery to the laptop chassis.
  6. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: étape 6, image 1 de 3 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: étape 6, image 2 de 3 Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: étape 6, image 3 de 3
    • Grip the corners of the battery.
    • Pull and lift the battery of its recess and remove it.
    • Be delicate when pulling the battery out at first. The small pins on its connector are easy to bend.
    • There is no cable for the battery. It disconnects when removed from its recess.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad X1 Carbon community for help.
Clay Eickemeyer
Membre depuis le 09/19/22
66 989 Réputation
453 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 287 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 89
30 derniers jours : 438
Total : 4,654
