Aller au contenu principal
Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: étape 1, image 1 de 2 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: étape 1, image 2 de 2
    • Orient the laptop so that it is bottom up, and the track pad is closet to you.
    • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen but will stay attached to the cover.
    • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
  2. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: étape 2, image 2 de 2
    • Using a Phillips #00 head screwdriver, remove the 3mm screw holding the wireless adapter to the motherboard.
  3. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: étape 3, image 1 de 3 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: étape 3, image 2 de 3 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: étape 3, image 3 de 3
    • Slide the chip to the right carefully until the wireless adapter pops out.
    • Disconnect the grey and black wires by lifting them off straight up until they pop off the wireless adapter.
    • The chip should be completely removed from the computer and you are done.
Beckham Richmond
Membre depuis le 02/10/20
466 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S7-G3, Regan Winter 2020 Membre de l'équipe Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 membres
8 tutoriels rédigés
Un commentaire
Hi, does the Lenovo X1 Extreme Gen 1 support Wifi 6 or 6e? If so what which card?
I tried the:
"AX210NGW WiFi Card, Wi-Fi 6E 11AX Wireless Module Expand to 6GHz MU-MIMO Tri-Band Bluetooth 5.3 Internal Network Adapter for Laptop, Support Windows 10/11 64bit, M.2/NGFF"
Wifi worked but Bluetooth wasn't recognized.
Captainturk - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 23
30 derniers jours : 49
Total : 1,872
