Aller au contenu principal
Lenovo ThinkPad X1 Yoga Battery Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X1 Yoga Battery Replacement, Back Cover: étape 1, image 1 de 3 Lenovo ThinkPad X1 Yoga Battery Replacement, Back Cover: étape 1, image 2 de 3 Lenovo ThinkPad X1 Yoga Battery Replacement, Back Cover: étape 1, image 3 de 3
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Battery Replacement, Speakers: étape 2, image 1 de 1
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Battery Replacement: étape 3, image 1 de 1
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Battery Replacement: étape 4, image 1 de 3 Lenovo ThinkPad X1 Yoga Battery Replacement: étape 4, image 2 de 3 Lenovo ThinkPad X1 Yoga Battery Replacement: étape 4, image 3 de 3
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
  5. Lenovo ThinkPad X1 Yoga Battery Replacement, Battery: étape 5, image 1 de 3 Lenovo ThinkPad X1 Yoga Battery Replacement, Battery: étape 5, image 2 de 3 Lenovo ThinkPad X1 Yoga Battery Replacement, Battery: étape 5, image 3 de 3
    • Lift the plastic black strip cover that's laying over the battery connector.
    • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
    • Gently pull the connector away from the battery to pull it out of the slot.
  6. Lenovo ThinkPad X1 Yoga Battery Replacement: étape 6, image 1 de 1
    • Lift and remove the battery away from the computer.
11 autres ont terminé cette réparation.
3 commentaires
Hello, I was able to install the battery on my X1 carbon, but the laptop is not detecting my battery. How to remove whitelisting on X1 carbon yoga 1st gen?
Delta Force - Réponse
Did you find a solution for your problem? Because i have the same problem since i changed my battery :/
Sarah -
Very useful instructions. I was able to replace the battery without any problems. Thank you very much.
Carlos Oppenheimer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 24
7 derniers jours : 198
30 derniers jours : 913
Total : 34,248
