Aller au contenu principal
Lenovo ThinkPad X270 SSD Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad X270 SSD Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Prepare your laptop for disassembly: étape 1, image 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo ThinkPad X270 SSD Replacement, Remove the micro SIM card tray: étape 2, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement, Remove the micro SIM card tray: étape 2, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement, Remove the micro SIM card tray: étape 2, image 3 de 3
    • A SIM eject tool or bit isn't long enough to eject the tray.
    • Insert a straightened paper clip into the micro SIM card tray hole on the right edge of the laptop.
    • Press the paper clip firmly into the hole to eject the tray.
    • Remove the tray.
    • When reinserting the tray, slide the arms of the tray into the rectangular metal slot.
  3. Lenovo ThinkPad X270 SSD Replacement, Battery information: étape 3, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Battery information: étape 3, image 2 de 2
    • Lay your laptop upside down to access the external battery.
    • Two sliding tabs secure the battery.
  4. Lenovo ThinkPad X270 SSD Replacement, Release the left tab: étape 4, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Release the left tab: étape 4, image 2 de 2
    • Slide the left tab, labeled 1, to the unlocked position—it'll click into place and release the left side of the battery.
  5. Lenovo ThinkPad X270 SSD Replacement, Remove the battery: étape 5, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement, Remove the battery: étape 5, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement, Remove the battery: étape 5, image 3 de 3
    • Hold the right tab, labeled 2, in the unlocked position and slide the battery out of its recess.
    • During reassembly, slide the battery into its recess until both tabs engage.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  6. Lenovo ThinkPad X270 SSD Replacement, Unfasten the back cover: étape 6, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Unfasten the back cover: étape 6, image 2 de 2
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
    • Don't try to completely remove the screws—they're secured to the back cover with delicate, plastic clips.
  7. Lenovo ThinkPad X270 SSD Replacement, Insert an opening pick: étape 7, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement, Insert an opening pick: étape 7, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement, Insert an opening pick: étape 7, image 3 de 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the bottom right edge of the back cover and frame.
    • Pry up the back cover to release the bottom right clips.
    • Leave the pick inserted in the bottom right corner.
  8. Lenovo ThinkPad X270 SSD Replacement, Release the bottom edge clips: étape 8, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement, Release the bottom edge clips: étape 8, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement, Release the bottom edge clips: étape 8, image 3 de 3
    • During the next two steps, position your pick downward at a 45-degree angle to help release the clips.
    • Slide the pick to the bottom left corner to release the bottom clips.
  9. Lenovo ThinkPad X270 SSD Replacement, Release the left edge clips: étape 9, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Release the left edge clips: étape 9, image 2 de 2
    • Insert your pick in the bottom left corner and slide the pick to the first USB port to release the left clips.
  10. Lenovo ThinkPad X270 SSD Replacement, Release the top corner clips: étape 10, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement, Release the top corner clips: étape 10, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement, Release the top corner clips: étape 10, image 3 de 3
    • Insert an opening tool between the top left corner of the back cover and frame.
    • Pry the back cover up to release the clips securing its top left corner.
    • Repeat the process on the top right corner.
  11. Lenovo ThinkPad X270 SSD Replacement, Release the top edge clips: étape 11, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement, Release the top edge clips: étape 11, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement, Release the top edge clips: étape 11, image 3 de 3
    • Five clips secure the top edge of the back cover.
    • Insert an opening tool in the gap between the back cover and frame, next to one of the clips.
    • Push the opening tool into the gap until the clip releases.
  12. Lenovo ThinkPad X270 SSD Replacement: étape 12, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement: étape 12, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement: étape 12, image 3 de 3
    • Push the opening tool between the back cover and frame at different points along the top edge to release the remaining clips.
  13. Lenovo ThinkPad X270 SSD Replacement, Remove the back cover: étape 13, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement, Remove the back cover: étape 13, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement, Remove the back cover: étape 13, image 3 de 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  14. Lenovo ThinkPad X270 SSD Replacement, Disconnect the internal battery: étape 14, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement, Disconnect the internal battery: étape 14, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement, Disconnect the internal battery: étape 14, image 3 de 3
  15. Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD enclosure: étape 15, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD enclosure: étape 15, image 2 de 2
    • Use a Phillips screwdriver to remove the 3.7 mm‑long screw securing the SSD enclosure to the frame.
  16. Lenovo ThinkPad X270 SSD Replacement, Reposition the SSD enclosure: étape 16, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Reposition the SSD enclosure: étape 16, image 2 de 2
    • Gently lay the SSD enclosure over the left edge of the laptop.
  17. Lenovo ThinkPad X270 SSD Replacement, Move the speaker cable: étape 17, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Move the speaker cable: étape 17, image 2 de 2
    • Use a spudger or your fingers to reposition the black and red speaker cable so you can access the SSD cable's socket on the motherboard.
  18. Lenovo ThinkPad X270 SSD Replacement, Disconnect the SSD cable: étape 18, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement, Disconnect the SSD cable: étape 18, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement, Disconnect the SSD cable: étape 18, image 3 de 3
    • Insert the point of a spudger under the metal locking clip that snaps around the perimeter of the SSD cable’s socket.
    • Swing the clip up and over the socket.
    • Gently pull the SSD cable straight out of its socket.
  19. Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD cover: étape 19, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD cover: étape 19, image 2 de 2
    • Lay the SSD enclosure upside down on your work surface.
    • Use a Phillips screwdriver to remove the two 3.7 mm‑long screws securing the SSD cover.
  20. Lenovo ThinkPad X270 SSD Replacement, Remove the SSD cover: étape 20, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Remove the SSD cover: étape 20, image 2 de 2
    • Remove the SSD cover.
  21. Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD: étape 21, image 1 de 2 Lenovo ThinkPad X270 SSD Replacement, Unfasten the SSD: étape 21, image 2 de 2
    • Use a Phillips screwdriver to remove the 3.1 mm‑long screw securing the SSD to its enclosure.
  22. Lenovo ThinkPad X270 SSD Replacement, Remove the SSD: étape 22, image 1 de 3 Lenovo ThinkPad X270 SSD Replacement, Remove the SSD: étape 22, image 2 de 3 Lenovo ThinkPad X270 SSD Replacement, Remove the SSD: étape 22, image 3 de 3
    • Hold the SSD enclosure down firmly against your workspace with one hand and pull the SSD straight out of its socket with your other hand.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
Check your repair by running hardware tests with Lenovo Diagnostics.
2 autres ont terminé cette réparation.
Spencer Day
Membre depuis le 09/14/22
54 992 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 309 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 110
30 derniers jours : 392
Total : 2,845
