Introduction
If you need to access your laptops trackpad, or need to replace your laptops battery please refer to this guide. This guide does not require any difficult or complicated steps. Do exercise caution before beginning this guide by ensuring that the laptop is unplugged and turned off. To complete the removal and/or the replacement of your battery, you will need a plastic opening tool, a Phillips #0 screwdriver, and a pair of tweezers.
Ce dont vous avez besoin
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 autres ont terminé cette réparation.
