Aller au contenu principal
Lenovo YOGA 730-15IKB Right Fan Replacement
Ce dont vous avez besoin
  1. Lenovo YOGA 730-15IKB Right Fan Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo YOGA 730-15IKB Right Fan Replacement, Bottom Cover: étape 1, image 2 de 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Right Fan Replacement: étape 2, image 1 de 2 Lenovo YOGA 730-15IKB Right Fan Replacement: étape 2, image 2 de 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Right Fan Replacement: étape 3, image 1 de 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Right Fan Replacement, Right Fan: étape 4, image 1 de 1
    • When the laptop is upside down, the right fan is on the left side of the laptop near the large metal RAM cover.
    • Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
    • You can also use the white tabs on the connector to push the cable free.
  5. Lenovo YOGA 730-15IKB Right Fan Replacement: étape 5, image 1 de 2 Lenovo YOGA 730-15IKB Right Fan Replacement: étape 5, image 2 de 2
    • Remove two 4mm Phillips #1 screws.
  6. Lenovo YOGA 730-15IKB Right Fan Replacement: étape 6, image 1 de 1
    • Pull the fan up and towards the front of the laptop.
Équipe
Cal Poly, Team S1-G6, White Winter 2020 Membre de l'équipe Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 membres
27 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 36
Total : 2,799
