Aller au contenu principal
Lenovo YOGA 730-15IKB Wireless Card Replacement
Ce dont vous avez besoin
  1. Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: étape 1, image 2 de 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Wireless Card Replacement: étape 2, image 1 de 2 Lenovo YOGA 730-15IKB Wireless Card Replacement: étape 2, image 2 de 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Wireless Card Replacement: étape 3, image 1 de 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Wireless Card Replacement, Wireless Card: étape 4, image 1 de 1
    • Remove the sticky tape from the top edge of the wireless card.
  5. Lenovo YOGA 730-15IKB Wireless Card Replacement: étape 5, image 1 de 3 Lenovo YOGA 730-15IKB Wireless Card Replacement: étape 5, image 2 de 3 Lenovo YOGA 730-15IKB Wireless Card Replacement: étape 5, image 3 de 3
    • Pull the black and white antenna wires off of the wireless card.
    • For reassembly, the white wire connects to the right terminal marked "1." The black wire connects to the left terminal marked "2."
  6. Lenovo YOGA 730-15IKB Wireless Card Replacement: étape 6, image 1 de 2 Lenovo YOGA 730-15IKB Wireless Card Replacement: étape 6, image 2 de 2
    • Remove one 2mm Phillips #1 screw.
  7. Lenovo YOGA 730-15IKB Wireless Card Replacement: étape 7, image 1 de 2 Lenovo YOGA 730-15IKB Wireless Card Replacement: étape 7, image 2 de 2
    • Pull the wireless card out of the socket at its resting angle.
    • Do not pull straight upward. Pull towards the hinges at the back of the laptop.
Ellis Ruckman
Membre depuis le 01/23/20
2 545 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S1-G6, White Winter 2020 Membre de l'équipe Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 membres
27 tutoriels rédigés
Un commentaire
I was able to use an intel AX210NGW WiFi 6 & BT 5.3 to work perfectly - plug and play. It worked at startup. I get download speeds nearly 1,000 Mb/s on a WiFi 6 network. Well worth the upgrade.
George - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 18
30 derniers jours : 64
Total : 3,399
