Aller au contenu principal
Lenovo Yoga 710-15IKB Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 710-15IKB Battery Replacement, Battery: étape 1, image 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Battery Replacement: étape 2, image 1 de 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Battery Replacement: étape 3, image 1 de 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Battery Replacement: étape 4, image 1 de 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Battery Replacement: étape 5, image 1 de 1
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Battery Replacement: étape 6, image 1 de 1
    • Gently lift and remove the battery.
15 autres ont terminé cette réparation.
Stephanie Alexander
Membre depuis le 09/28/17
745 Réputation
3 tutoriels rédigés
Équipe
University of Maine, Team S1-G5, Diaz Fall 2017 Membre de l'équipe University of Maine, Team S1-G5, Diaz Fall 2017
UMAINE-DIAZ-F17S1G5
4 membres
10 tutoriels rédigés
2 commentaires
I had to use a PH000 screwdriver and was only able to remove 1 of the battery screws from the original Lenovo battery. Any suggestions on how to remove the others? Where can I get replacement screws?
karenosickey - Réponse
The battery cable requires a lot of force to disconnect; tweezers won't cut it. It's also difficult to reconnect the battery. I used two pairs of needle-nose pliers to squeeze the connector into the socket on both sides.
jkvmyxud - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 25
30 derniers jours : 100
Total : 18,571
