Aller au contenu principal
Lenovo Yoga 720-15IKB Fan Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: étape 1, image 1 de 3 Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: étape 1, image 2 de 3 Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: étape 1, image 3 de 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Fan Replacement: étape 2, image 1 de 2 Lenovo Yoga 720-15IKB Fan Replacement: étape 2, image 2 de 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Fan Replacement, Fan: étape 3, image 1 de 2 Lenovo Yoga 720-15IKB Fan Replacement, Fan: étape 3, image 2 de 2
    • Remove the six 5.2mm Torx T5 screws holding the fan in place.
    • Remove the five 5.0mm Torx T5 screws holding the fan in place.
  4. Lenovo Yoga 720-15IKB Fan Replacement: étape 4, image 1 de 3 Lenovo Yoga 720-15IKB Fan Replacement: étape 4, image 2 de 3 Lenovo Yoga 720-15IKB Fan Replacement: étape 4, image 3 de 3
    • Disconnect the two fan wire connectors.
    • Firmly pull the connector out horizontally away from the socket.
    • Carefully lift the fan up and out.
6 autres ont terminé cette réparation.
Shaina Bagri
Membre depuis le 01/23/20
447 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S19-G3, White Winter 2020 Membre de l'équipe Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 membres
25 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 61
Total : 3,498
