Aller au contenu principal
Lenovo Yoga 730-13IKB Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Yoga 730-13IKB Battery Replacement, Back Case: étape 1, image 1 de 3 Lenovo Yoga 730-13IKB Battery Replacement, Back Case: étape 1, image 2 de 3 Lenovo Yoga 730-13IKB Battery Replacement, Back Case: étape 1, image 3 de 3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Battery Replacement: étape 2, image 1 de 3 Lenovo Yoga 730-13IKB Battery Replacement: étape 2, image 2 de 3 Lenovo Yoga 730-13IKB Battery Replacement: étape 2, image 3 de 3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Battery Replacement: étape 3, image 1 de 1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
  4. Lenovo Yoga 730-13IKB Battery Replacement, Battery: étape 4, image 1 de 2 Lenovo Yoga 730-13IKB Battery Replacement, Battery: étape 4, image 2 de 2
    • Remove the four 3.5mm Phillips #0 screws securing the battery.
  5. Lenovo Yoga 730-13IKB Battery Replacement: étape 5, image 1 de 3 Lenovo Yoga 730-13IKB Battery Replacement: étape 5, image 2 de 3 Lenovo Yoga 730-13IKB Battery Replacement: étape 5, image 3 de 3
    • Disconnect the battery cable by gently pulling it straight out of the connector.
    • The battery connector does not lock and requires light pressure to insert and remove. To reinstall the battery cable, hold onto the black housing and push it into the motherboard connector.
  6. Lenovo Yoga 730-13IKB Battery Replacement: étape 6, image 1 de 3 Lenovo Yoga 730-13IKB Battery Replacement: étape 6, image 2 de 3 Lenovo Yoga 730-13IKB Battery Replacement: étape 6, image 3 de 3
    • Remove the battery by pulling up near the white label and lifting diagonally away from the laptop.
    • Consider using a plastic opening tool to gently pry up near the white label if the battery seems stuck.
    • To reinstall the battery, carefully align its mounting holes with the plastic pins on the laptop frame.
12 autres ont terminé cette réparation.
Colin Reay
Membre depuis le 01/23/20
848 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S1-G1, White Winter 2020 Membre de l'équipe Cal Poly, Team S1-G1, White Winter 2020
CPSU-WHITE-W20S1G1
3 membres
14 tutoriels rédigés
3 commentaires
Overall, this was very helpful: pictures were good, it took about the time proposed (I'm a newbie at this kind of thing), and since I had a 720 and a730 that both required new batteries, I bought the toolkit which really helped. I would add that, in the first step, where you're prying away next the hinges, there appear to be a some small 'nubs' between the hinges that hold the case in place. It doesn't mention it, but you have to work your way across between the hinges, to make sure it's loosened, otherwise the case won't come apart. Other than that, I found everything went exactly as described. I Fixed It, so thanks iFixit!
frank g - Réponse
Great instructions mine only took 10 minutes to replace, but I 'm pretty handy.
Michael Thompson - Réponse
5 or 10 minutes. Tool kit is great. Battery is perfect. Product design by Lenovo was excellent to allowsuch a simple battery change. David
david dodds - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 38
30 derniers jours : 160
Total : 10,292
