Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mac mini Mid 2011 PRAM Battery Replacement
Ce dont vous avez besoin
  1. Mac mini Mid 2011 PRAM Battery Replacement, Bottom Cover: étape 1, image 1 de 2 Mac mini Mid 2011 PRAM Battery Replacement, Bottom Cover: étape 1, image 2 de 2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
    Demander à FixBot
    Ajouter un commentaire
  2. Mac mini Mid 2011 PRAM Battery Replacement: étape 2, image 1 de 1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
    Demander à FixBot
  3. Mac mini Mid 2011 PRAM Battery Replacement, Fan: étape 3, image 1 de 1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
    Demander à FixBot
  4. Mac mini Mid 2011 PRAM Battery Replacement: étape 4, image 1 de 1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
    Demander à FixBot
  5. Mac mini Mid 2011 PRAM Battery Replacement: étape 5, image 1 de 3 Mac mini Mid 2011 PRAM Battery Replacement: étape 5, image 2 de 3 Mac mini Mid 2011 PRAM Battery Replacement: étape 5, image 3 de 3
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
    • Do not pry at the socket, or you may rip it from the logic board.
    • Remove the fan.
    Demander à FixBot
  6. Mac mini Mid 2011 PRAM Battery Replacement, Cowling: étape 6, image 1 de 1
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
    Demander à FixBot
  7. Mac mini Mid 2011 PRAM Battery Replacement: étape 7, image 1 de 1
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
    Demander à FixBot
  8. Mac mini Mid 2011 PRAM Battery Replacement, Antenna Plate: étape 8, image 1 de 1
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
    • When putting back together:
    • It can be difficult to get the hard drive seated correctly such that the antenna plate fits in place correctly. If the screw holes don't line up with those on the hard drive, make sure that the two pins that are in the back of the hard drive are properly seated in the holes at the back of the case, above the housing for the second hard drive.
    • The antenna attaches directly to the hard drive (red markers), therefore attaching the antenna can move the hard drive around and loosen the connection of the hard drive cable to the logic board.
    Demander à FixBot
  9. Mac mini Mid 2011 PRAM Battery Replacement: étape 9, image 1 de 2 Mac mini Mid 2011 PRAM Battery Replacement: étape 9, image 2 de 2
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
    Demander à FixBot
  10. Mac mini Mid 2011 PRAM Battery Replacement: étape 10, image 1 de 1
    • Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
    Demander à FixBot
  11. Mac mini Mid 2011 PRAM Battery Replacement: étape 11, image 1 de 1
    • Remove the antenna plate from the mini.
    Demander à FixBot
  12. Mac mini Mid 2011 PRAM Battery Replacement, Logic Board: étape 12, image 1 de 2 Mac mini Mid 2011 PRAM Battery Replacement, Logic Board: étape 12, image 2 de 2
    • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
    Demander à FixBot
  13. Mac mini Mid 2011 PRAM Battery Replacement: étape 13, image 1 de 1
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
    • Make sure to pry up from beneath the wires and not underneath the socket.
    Demander à FixBot
  14. Mac mini Mid 2011 PRAM Battery Replacement: étape 14, image 1 de 1
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
    Demander à FixBot
  15. Mac mini Mid 2011 PRAM Battery Replacement: étape 15, image 1 de 3 Mac mini Mid 2011 PRAM Battery Replacement: étape 15, image 2 de 3 Mac mini Mid 2011 PRAM Battery Replacement: étape 15, image 3 de 3
    Outil utilisé dans cette étape :
    Mac mini Logic Board Removal Tool
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case.
    • Remove the Mac mini Logic Board Removal tool.
    Demander à FixBot
  16. Mac mini Mid 2011 PRAM Battery Replacement: étape 16, image 1 de 1
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use your fingers to disconnect the DC-In cable from the logic board.
    • Pull the power cable connector toward the front side of the mini.
    Demander à FixBot
  17. Mac mini Mid 2011 PRAM Battery Replacement: étape 17, image 1 de 1
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
    Demander à FixBot
  18. Mac mini Mid 2011 PRAM Battery Replacement, PRAM Battery: étape 18, image 1 de 1
    • The PRAM battery is located on the top side of the logic board.
    • Use the tip of a spudger to carefully pry the PRAM battery up and out of its holder on the logic board.
    Demander à FixBot
  19. Mac mini Mid 2011 PRAM Battery Replacement: étape 19, image 1 de 1
    • Remove the PRAM battery from the logic board.
    • The PRAM battery is a commonly available BR2032 coin-cell.
    Demander à FixBot
24 autres ont terminé cette réparation.
5 commentaires de tutoriel
Great directions. Unfortunately it’s the logic board. But thanks.
Craig Wallace - Réponse Partager
Second time I have used this guide. Thorough and NO fluff…i.e. When the guide says “gently" or “can be difficult" those words are there for a reason. This one is direct and to the point without a head in the clouds. Leave that to me!
John Heins - Réponse Partager
By mail order only and from China for me, Ordered two BR2032 coin cells 12 days ago and still waiting. I doubt if you would find this exact type anywhere locally in a store. You could go with a CR2032 which is found more easily but after what I found online it does make a difference.
The main difference between these two types resides in their electrode.
While similar, the BR2032 uses carbon monofluoride as the positive electrode.
The CR2032 uses manganese dioxide for the positive electrode
David Bell - Réponse Partager
There is a difference between CR2032 and BR2032. While the dimensions are the same, the chemistries are different. The BR2032 are preferred for maintaining computer PRAM or BIOS because at temperatures above 60c (140f) the CR type battery decays faster and has more voltage sag. It is not unusual for the inside of your computer to reach these temperatures. In relatively speaking higher drain applications -like many consumer use applications, the chemistry of the CR type battery is advantageous as it provides more steady voltage under higher drains at temperatures under 60c. In short, after 3 or 4 years in a system the CR chemistry battery might not be providing close enough to the 3v for the system clock to maintain the purest accuracy. But can you use either?- yes. But what does Apple put as factory original? - the BR chemistry.
Why is a fan listed as a part? Is it expected to be destroyed in removal? That seems unlikely.
William R. Dickson - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 22
30 derniers jours : 94
Total : 42,274
