Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Core Duo Optical Drive Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. MacBook Core Duo Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    Demander à FixBot
    Ajouter un commentaire
  2. MacBook Core Duo Optical Drive Replacement: étape 2, image 1 de 1
    • Lift the battery out of the computer.
    Demander à FixBot
  3. MacBook Core Duo Optical Drive Replacement, Memory Cover: étape 3, image 1 de 1
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
    Demander à FixBot
  4. MacBook Core Duo Optical Drive Replacement: étape 4, image 1 de 1
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
    Demander à FixBot
  5. MacBook Core Duo Optical Drive Replacement, Upper Case: étape 5, image 1 de 1
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
    Demander à FixBot
  6. MacBook Core Duo Optical Drive Replacement: étape 6, image 1 de 1
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
    Demander à FixBot
  7. MacBook Core Duo Optical Drive Replacement: étape 7, image 1 de 1
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    Demander à FixBot
  8. MacBook Core Duo Optical Drive Replacement: étape 8, image 1 de 1
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    Demander à FixBot
  9. MacBook Core Duo Optical Drive Replacement: étape 9, image 1 de 1
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
    Demander à FixBot
  10. MacBook Core Duo Optical Drive Replacement: étape 10, image 1 de 1
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
    Demander à FixBot
  11. MacBook Core Duo Optical Drive Replacement: étape 11, image 1 de 1
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
    Demander à FixBot
  12. MacBook Core Duo Optical Drive Replacement: étape 12, image 1 de 1
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    Demander à FixBot
  13. MacBook Core Duo Optical Drive Replacement, Optical Drive: étape 13, image 1 de 1
    • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
    Demander à FixBot
  14. MacBook Core Duo Optical Drive Replacement: étape 14, image 1 de 1
    • Remove the two Phillips screws from the front edge of the optical drive.
    • The shorter screw (3 mm) is recessed nearest the RAM modules. The other is 3.5 mm.
    Demander à FixBot
  15. MacBook Core Duo Optical Drive Replacement: étape 15, image 1 de 1
    • Disconnect the orange optical drive ribbon cable from the logic board.
    Demander à FixBot
  16. MacBook Core Duo Optical Drive Replacement: étape 16, image 1 de 1
    • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
    Demander à FixBot
  17. MacBook Core Duo Optical Drive Replacement: étape 17, image 1 de 1
    • Disconnect the (once again) newly-revealed hard drive cable.
    Demander à FixBot
  18. MacBook Core Duo Optical Drive Replacement: étape 18, image 1 de 1
    • Peel up the foil tape between the fan and the optical drive.
    • Remove the 8.5 mm Phillips screw securing the display data cable to the metal framework.
    Demander à FixBot
  19. MacBook Core Duo Optical Drive Replacement: étape 19, image 1 de 1
    • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
    Demander à FixBot
  20. MacBook Core Duo Optical Drive Replacement: étape 20, image 1 de 1
    • Remove the 2.8 mm Phillips screw securing the optical drive.
    • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
    • Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
    • After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
    Demander à FixBot
  21. MacBook Core Duo Optical Drive Replacement: étape 21, image 1 de 1
    • Lift the Bluetooth antenna board from the right side of the optical drive.
    Demander à FixBot
    • Deroute the hard drive cable from along the front of the optical drive.
    Demander à FixBot
  22. MacBook Core Duo Optical Drive Replacement: étape 23, image 1 de 1
    • Lift the front edge of the optical drive and slide it up and out of the computer.
    Demander à FixBot
  23. MacBook Core Duo Optical Drive Replacement, Optical Drive Cable: étape 24, image 1 de 1
    • Peel up the orange tape partially covering the orange optical drive cable.
    Demander à FixBot
  24. MacBook Core Duo Optical Drive Replacement: étape 25, image 1 de 1
    • Disconnect the orange cable from the optical drive.
    Demander à FixBot
  25. MacBook Core Duo Optical Drive Replacement, Optical Drive: étape 26, image 1 de 1
    • Use a spudger to carefully pry the silver metal bracket off the left side of the optical drive. Be careful not to bend the bracket, as it is very thin and bends easily. If the bracket doesn't come free easily, heating the adhesive may make prying the bracket off easier.
    Demander à FixBot
  26. MacBook Core Duo Optical Drive Replacement: étape 27, image 1 de 1
    • Peel up the L-shaped piece of black tape from the top of the drive.
    • You'll want to reapply this tape in the same position on your replacement drive.
    Demander à FixBot
  27. MacBook Core Duo Optical Drive Replacement: étape 28, image 1 de 1
    • Peel up the silver foil tape from the optical drive.
    Demander à FixBot
  28. MacBook Core Duo Optical Drive Replacement: étape 29, image 1 de 1
    • Remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
    • This bracket is designed to slide back and forth slightly, so don't tighten the screws so much that the bracket is unable to slide.
    Demander à FixBot
  29. MacBook Core Duo Optical Drive Replacement: étape 30, image 1 de 1
    • Use a spudger to pry the gray Bluetooth antenna holder off the top of the optical drive.
    • You'll want to reapply this piece in the same position on your replacement drive.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    Demander à FixBot
146 autres ont terminé cette réparation.
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
4 commentaires de tutoriel
Dude, I've done a little work on PCs but not on Macs. This optical drive swap-out was my first time. Super KUDOS to the folks who contributed to this guide (including the helpful notes on practically every page) and the terrific pictures...!!!! I did it in under two hours - without a hitch. THANK YOU...!!!
HappyPappy - Réponse Partager
I almost forgot. I got this SuperDrive on eBay - Item:MacBook Pro DVD±RW Superdrive Burner GWA-4080MA - $59.99. That's the one I just installed; from a place called "power_optical". What a deal...!
Citation de HappyPappy :
i have a macbook pro 17“ bought at 2007 and its dvd burner doesn´t work anymore... this you bought does work with mine?
thank you
franK - Réponse Partager
this guide is awesome and made the swap of the defective DVD player a breeze..
thanks for posting.
roeiboot - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 24
30 derniers jours : 142
Total : 223,734
