Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MacBook Pro 13" Retina Display Mid 2014 Fan Replacement
Ce dont vous avez besoin
  1. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    Demander à FixBot
  2. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 2, image 1 de 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
    Demander à FixBot
  3. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 3, image 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 3, image 2 de 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    Demander à FixBot
  4. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Battery Connector: étape 4, image 1 de 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
    Demander à FixBot
  5. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 5, image 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 5, image 2 de 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    Demander à FixBot
  6. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 6, image 1 de 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    Demander à FixBot
  7. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: étape 7, image 1 de 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: étape 7, image 2 de 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Heat Sink: étape 7, image 3 de 3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
    Demander à FixBot
  8. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 8, image 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 8, image 2 de 2
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
    Demander à FixBot
  9. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 9, image 1 de 1
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
    Demander à FixBot
  10. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 10, image 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 10, image 2 de 2
    Demander à FixBot
  11. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Fan: étape 11, image 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement, Fan: étape 11, image 2 de 2
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
    Demander à FixBot
  12. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 12, image 1 de 2 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 12, image 2 de 2
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
    Demander à FixBot
  13. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 13, image 1 de 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 13, image 2 de 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 13, image 3 de 3
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
    Demander à FixBot
  14. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 14, image 1 de 1
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
    Demander à FixBot
  15. MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 15, image 1 de 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 15, image 2 de 3 MacBook Pro 13" Retina Display Mid 2014 Fan Replacement: étape 15, image 3 de 3
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
    Demander à FixBot
28 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
477 299 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
25 721 tutoriels rédigés
4 commentaires de tutoriel
Very clear guide, and highly informative photos. It might be useful to add that the PL5 screws on the back of the case do not insert vertically. These insert at a slight angle and attempting to insert them straight will cause cross treading.
Robert Chave - Réponse Partager
Simple and clear step by step instructions.
cosilverturq - Réponse Partager
What is the use of the four foam stickers in step 9? Mine don’t stick anymore after taking out.
Visalbotr Chan - Réponse Partager
A mi me ha pasado lo mismo. Supongo que sirve para ejercer una pequeña presión sobre los tornillos. Yo le he puesto unas pegatinas, recortadas, de las que se usan para tope de muebles, para que no rocen, y creo que hacen el apaño.
Jose Luis - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 44
30 derniers jours : 172
Total : 49,466
