Aller au contenu principal
MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement
Ce dont vous avez besoin
  1. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Remove the lower case screws: étape 1, image 1 de 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Lift the lower case away: étape 2, image 1 de 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Battery: étape 3, image 1 de 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Fan: étape 4, image 1 de 3 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Fan: étape 4, image 2 de 3 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Fan: étape 4, image 3 de 3
    • Use a spudger to pry up the fan connector out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  5. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 5, image 1 de 1
    • Remove the following three screws:
    • One 7 mm T6 Torx screw
    • Two 5.4 mm T6 Torx screws
  6. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 6, image 1 de 1
    • Lift the fan out of the upper case.
  7. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Logic Board: étape 7, image 1 de 3 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Logic Board: étape 7, image 2 de 3 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Logic Board: étape 7, image 3 de 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Gently pull the display data cable connector away parallel to the board.
    • Do not pull the connector upwards, or you may damage the connector.
  8. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 8, image 1 de 2 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 8, image 2 de 2
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 8.6 mm Phillips
    • One 5.6 mm Phillips
    • Lift the display data cable bracket out of the upper case.
  9. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 9, image 1 de 1
    • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
  10. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 10, image 1 de 1
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and can be easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
  11. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 11, image 1 de 3 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 11, image 2 de 3 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 11, image 3 de 3
    • Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
  12. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 12, image 1 de 3 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 12, image 2 de 3 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 12, image 3 de 3
    • Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
    • Use your spudger to slide the keyboard ribbon cable out of its socket.
  13. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 13, image 1 de 1
    • Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
  14. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 14, image 1 de 3 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 14, image 2 de 3 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 14, image 3 de 3
    • Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
    • Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
  15. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 15, image 1 de 1
    • Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
  16. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 16, image 1 de 1
    • Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
  17. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 17, image 1 de 1
    • Remove the following screws:
    • Two 7 mm T6 Torx screws from the DC-In board
    • Five 3.3 mm T6 Torx screws
    • Two 4 mm T6 Torx screws
  18. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 18, image 1 de 2 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 18, image 2 de 2
    • Removing the battery before lifting out the logic board is not strictly required, but makes removing the logic board easier and safer. If you leave your battery in, be especially careful not to bend the logic board against the battery's case near its bar code.
    • Remove the following Tri-point screws securing the battery to the upper case:
    • One 5.5 mm Tri-point screw
    • One 13.5 mm Tri-point screw
    • Lift the battery out of the upper case.
  19. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 19, image 1 de 2 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 19, image 2 de 2
    • Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
    • Pull the logic board away from the side of the upper case and remove it, minding the DC-In board that may get caught.
  20. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Heat Sink: étape 20, image 1 de 1
    • Remove the four 8.5 mm Phillips screws securing the heat sink to the logic board.
    • A spring is held under each of these screws. Be careful not to lose it.
  21. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 21, image 1 de 1
    • Gently lift the heat sink off the logic board.
    • When you mount the heat sink back onto the logic board, be sure to apply a new layer of thermal paste. We have a guide that makes replacing the thermal paste easy.
  22. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement, Logic Board: étape 22, image 1 de 1
    • Peel off the tape covering the microphone cable connector and left speaker cable connector.
  23. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 23, image 1 de 1
    • Use the flat end of a spudger to pry the left speaker connector up off the logic board.
  24. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 24, image 1 de 1
    • Use the flat end of a spudger to pry the microphone cable connector up off the logic board.
  25. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 25, image 1 de 1
    • Carefully peel the left speaker/microphone assembly off the adhesive securing it to the logic board.
  26. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 26, image 1 de 1
    • Disconnect the DC-In board by pulling its connector away from the socket on the logic board.
  27. MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 27, image 1 de 2 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement: étape 27, image 2 de 2
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
    • Logic board remains.
140 autres ont terminé cette réparation.
5 commentaires de tutoriel
My Mac book pro mid 2010 unibody 13' suddenly stopped working and was diagnosed for water damage. followed step by step instruction to disassemble and reassemble the logic board. Even the cleaning procedure for the water damage was available on the ifixit website. The author's instructions are very clear and precise and the colour coded markings about the screws and all other instruction are very precise. My mac book is now back to life after two years. THANKS A LOT to IFIXIT and the AUTHOR.
rishi - Réponse
Thanks so much. A Wonderful Resourse. The Logic board Tutorial is great and computer is working so far!
Logic board purchased from ifix also!
Shelley McKaughan - Réponse
Absolutely great guide for logic board replacement. iFixIt.com was also great in overnighting a replacement to the first logic board they sent me because it was missing the fan connector. Love the warranty on their boards. Worth the extra money vs buying on eBay, etc.
Dan - Réponse
Is a Macbook Pro mid 2012 mobo compatible with this macbook pro mid 2010 ?
phfred - Réponse
nope, It looks like it would, but no
Ben Capehart -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 18
7 derniers jours : 113
30 derniers jours : 450
Total : 227,515
