Aller au contenu principal
Microsoft Surface Laptop 3 13.5" Feet Replacement
Ce dont vous avez besoin
  1. Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: étape 1, image 1 de 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: étape 1, image 2 de 2
    • Flip the laptop over and place it on your work surface, feet facing up.
  2. Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: étape 2, image 1 de 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: étape 2, image 2 de 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  3. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: étape 3, image 1 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: étape 3, image 2 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: étape 3, image 3 de 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  4. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: étape 4, image 1 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: étape 4, image 2 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: étape 4, image 3 de 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  5. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: étape 5, image 1 de 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: étape 5, image 2 de 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  6. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: étape 6, image 1 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: étape 6, image 2 de 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: étape 6, image 3 de 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Carsten Frauenheim
Membre depuis le 03/10/20
114 422 Réputation
338 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 269 tutoriels rédigés
Un commentaire
Nice, that good for me, first time :D
TrungLun0112 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 38
30 derniers jours : 171
Total : 5,758
