Introduction
In this guide, we will walk through how to replace the screen of the Motorola Moto G3.
Use the plastic opening tool to open the back cover as shown in the photo. Use the plastic opening tool to open the back cover as shown in the photo.
  • Use the plastic opening tool to open the back cover as shown in the photo.
Ajouter un commentaire
Heat an iOpener in the microwave for 30 seconds.
  • Heat an iOpener in the microwave for 30 seconds.
  • Place the heated iOpener on all four edges of the screen for approximately 2 minutes.
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
Apply the plastic opening tool on the edge of the screen near the front camera.
  • Apply the plastic opening tool on the edge of the screen near the front camera.
  • After creating enough space, allow the opening tool to be inserted on the side of the phone.
  • Create another space on the other side of the screen.
  • Leave the opening tool inserted.
  • Carefully apply the larger plastic opening tool by sliding it through the longer edge of the screen.
A strip will be attached to the motherboard as shown. Using tweezers, carefully detach the strip from the motherboard. Using tweezers, carefully detach the strip from the motherboard.
  • A strip will be attached to the motherboard as shown.
  • Using tweezers, carefully detach the strip from the motherboard.
That strip is the LCD display assembly flex cable, and it is attached to the motherboard via a ZIF connector. Using tweezers or a spudger, the plastic latch (which is on the side nearest the edge of the phone) must be gently lifted up away from the phone’s edge. Only then can the flex cable be safely (and carefully) removed.
If the repairer attempts to pull the flex cable out of its connector without first opening the latch, either the latch or the flex cable itself is likely to break, greatly complicating the repair.
Bonnie Baxter - Réponse
Irkan Notta
Membre depuis le 19/03/2018
567 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team S5-G3, Williams Spring 2018 Membre de l'équipe Baylor, Team S5-G3, Williams Spring 2018
BU-WILLIAMS-S18S5G3
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 24
30 derniers jours : 99
Total : 119
