Introduction
Use this guide to replace your digitizer.
Power off your Android before beginning disassembly. Place the plastic opening tool under the tab and lift up.
  • Power off your Android before beginning disassembly.
  • Place the plastic opening tool under the tab and lift up.
  • Remove the top and bottom tabs.
Ajouter un commentaire
Use a pair of tweezers to remove the thin golden piece of metal on the bottom panel.
  • Use a pair of tweezers to remove the thin golden piece of metal on the bottom panel.
Use a T3 screw head to remove the six (4mm) screws.
  • Use a T3 screw head to remove the six (4mm) screws.
Push the nylon spudger through the top right hole to push on the front screen. Use the plastic opening tool to separate the front screen from the rear. Use the plastic opening tool to separate the front screen from the rear.
  • Push the nylon spudger through the top right hole to push on the front screen.
  • Use the plastic opening tool to separate the front screen from the rear.
Use a metal spudger to remove the connector located above the battery on the rear case. Separate the front and rear assemblies. Separate the front and rear assemblies.
  • Use a metal spudger to remove the connector located above the battery on the rear case.
  • Separate the front and rear assemblies.
Take the front assembly. Remove the copper tape with a pair of tweezers. Remove the copper tape with a pair of tweezers.
  • Take the front assembly.
  • Remove the copper tape with a pair of tweezers.
Lift the digitizer wiring with a pair of tweezers but do not pull out the wiring. Do not use a heat gun to remove the tape. Do not use a heat gun to remove the tape.
  • Lift the digitizer wiring with a pair of tweezers but do not pull out the wiring.
  • Do not use a heat gun to remove the tape.
Begin to separate the front screen from the metal plate with the plastic opening tool.
  • Begin to separate the front screen from the metal plate with the plastic opening tool.
Carefully fold the digitizer such that it ends up in the middle of the wiring plate. Gently pull the metal plate off of the digitizer in a slight counterclockwise manner as to not damage the wiring plate.
  • Carefully fold the digitizer such that it ends up in the middle of the wiring plate.
  • Gently pull the metal plate off of the digitizer in a slight counterclockwise manner as to not damage the wiring plate.
Kenji Fong
Membre depuis le 23/01/2018
813 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S1-G1, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S1-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 21
30 derniers jours : 113
Total : 278
