Introduction
Use this guide to replace the rear facing camera.
Power off your Android before beginning disassembly. Place the plastic opening tool under the tab and lift up.
  • Power off your Android before beginning disassembly.
  • Place the plastic opening tool under the tab and lift up.
  • Remove the top and bottom tabs.
Ajouter un commentaire
Use a pair of tweezers to remove the thin golden piece of metal on the bottom panel.
  • Use a pair of tweezers to remove the thin golden piece of metal on the bottom panel.
Use a T3 screw head to remove the six (4mm) screws.
  • Use a T3 screw head to remove the six (4mm) screws.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Push the nylon spudger through the top right hole to push on the front screen. Use the plastic opening tool to separate the front screen from the rear. Use the plastic opening tool to separate the front screen from the rear.
  • Push the nylon spudger through the top right hole to push on the front screen.
  • Use the plastic opening tool to separate the front screen from the rear.
Use a metal spudger to remove the connector located above the battery on the rear case. Separate the front and rear assemblies. Separate the front and rear assemblies.
  • Use a metal spudger to remove the connector located above the battery on the rear case.
  • Separate the front and rear assemblies.
Use a metal spudger to unfasten the camera. Use a metal spudger to unfasten the camera.
  • Use a metal spudger to unfasten the camera.
Use a pair of tweezers to pull the camera until it disconnects. Pull straight back instead of vertically on the camera.
  • Use a pair of tweezers to pull the camera until it disconnects.
  • Pull straight back instead of vertically on the camera.
Kenji Fong
Membre depuis le 23/01/2018
813 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S1-G1, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S1-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 5
7 derniers jours : 22
30 derniers jours : 87
Total : 228
