Introduction
This guide will walk you through the steps to replace the LCD screen for your camera.
Pièces
Aucune pièce nécessaire.
'Click' the battery door over to the side.
  • 'Click' the battery door over to the side.
Ajouter un commentaire
Open the battery door. Inside is the memory card and the battery.
  • Open the battery door. Inside is the memory card and the battery.
  • Click over the orange tab and take out the battery.
  • Close the battery lid by pushing it down and sliding it back.
Remove the four screws located on bottom of camera.     (.086in screws)
  • Remove the four screws located on bottom of camera. (.086in screws)
Remove the two screws, then remove the panel. (.113in screws) Remove the two screws, then remove the panel. (.113in screws)
  • Remove the two screws, then remove the panel. (.113in screws)
Remove panel on right side (front view) by removing these two screws. (.196in screws) Remove single screw set underneath panel. (0.083in screw) Remove single screw set underneath panel. (0.083in screw)
  • Remove panel on right side (front view) by removing these two screws. (.196in screws)
  • Remove single screw set underneath panel. (0.083in screw)
Remove the two screws attaching the back panel to the body on the left side. (.188in screws)
  • Remove the two screws attaching the back panel to the body on the left side. (.188in screws)
Gently pull off back cover
  • Gently pull off back cover
Remove the two screws holding on the back panel.  Then remove the three screws on the A/V Out tab (left side). (.188in screws) Remove tab.
  • Remove the two screws holding on the back panel. Then remove the three screws on the A/V Out tab (left side). (.188in screws)
  • Remove tab.
Remove the two screws attaching the front panel to the body on the left side. (.18in screws)
  • Remove the two screws attaching the front panel to the body on the left side. (.18in screws)
Flip up front panel.
  • Flip up front panel.
  • There should be wires still attaching the panel to body. DO NOT TRY TO PULL OFF COMPLETELY
Remove three screws as shown. (Right screw:0.084in, Left screw:0.088in, Middle screw:0.114in)
  • Remove three screws as shown. (Right screw:0.084in, Left screw:0.088in, Middle screw:0.114in)
Carefully pull orange LCD connector up and out of the port.
  • Carefully pull orange LCD connector up and out of the port.
  • Be careful to pull vertically while pushing the black tab upwards
Remove the screw below the LCD (.124in)
  • Remove the screw below the LCD (.124in)
Carefully pull out the plug connecting the LCD to the motherboard.
  • Carefully pull out the plug connecting the LCD to the motherboard.
You can now remove the LCD from the camera body.
  • You can now remove the LCD from the camera body.
  • Insert new LCD and reassemble using the steps in reverse order.
Luke Baumann
Membre depuis le 13/04/2011
121 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 8-5, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 8-5, Regan Spring 2011
CPSU-REGAN-S11S8G5
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 2,405
