Introduction
The speed (1-2) Switch is either stuck or won't change speed of rotation.
Pièces
Aucune pièce nécessaire.
Using a Torx T20 screwdriver, remove the four screws attaching the back plate. Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
Ajouter un commentaire
Remove the five screws attaching the drill handle.
  • Remove the five screws attaching the drill handle.
Remove the 4 screws attaching the front of the casing. Remove the 4 screws attaching the front of the casing.
  • Remove the 4 screws attaching the front of the casing.
Locate small metal bar above plastic part of drill.
  • Locate small metal bar above plastic part of drill.
  • Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
If the bar moves, next check the small plastic switch that is numbered 1 and 2. Make sure the small tabs on the underside of the switch that move the bar are intact.
  • If the bar moves, next check the small plastic switch that is numbered 1 and 2.
  • Make sure the small tabs on the underside of the switch that move the bar are intact.
  • Replace switch as needed.
2 autre(s) ont terminé cette réparation.
Evan Long
Membre depuis le 15/04/2010
232 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 15-48, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 3,194
