Aller au contenu principal
Removinging Panasonic DVD-RV31 Player Rear Panel
Ce dont vous avez besoin
  1. Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: étape 1, image 1 de 2 Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: étape 1, image 2 de 2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  2. Removinging Panasonic DVD-RV31 Player Rear Panel: étape 2, image 1 de 1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  3. Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: étape 3, image 1 de 2 Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: étape 3, image 2 de 2
    • Be sure case cover has been removed prior to back panel removal.
    • Remove 5 screws from panel, as shown.
  4. Removinging Panasonic DVD-RV31 Player Rear Panel: étape 4, image 1 de 2 Removinging Panasonic DVD-RV31 Player Rear Panel: étape 4, image 2 de 2
    • Use flat-head screwdriver to push in square tabs, located on each side of the back panel.
    • Use caution, the edges are sharp.
Kevin
Membre depuis le 04/26/11
375 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 18-20, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 2,270
