Aller au contenu principal
Samsung Chromebook 3 Daughterboard Replacement
Ce dont vous avez besoin
  1. Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: étape 1, image 1 de 2 Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: étape 1, image 2 de 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Daughterboard Replacement: étape 2, image 1 de 3 Samsung Chromebook 3 Daughterboard Replacement: étape 2, image 2 de 3 Samsung Chromebook 3 Daughterboard Replacement: étape 2, image 3 de 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Daughterboard Replacement: étape 3, image 1 de 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Daughterboard Replacement, Battery: étape 4, image 1 de 2 Samsung Chromebook 3 Daughterboard Replacement, Battery: étape 4, image 2 de 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Daughterboard Replacement: étape 5, image 1 de 2 Samsung Chromebook 3 Daughterboard Replacement: étape 5, image 2 de 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Daughterboard Replacement: étape 6, image 1 de 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: étape 7, image 1 de 2 Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: étape 7, image 2 de 2
    • Before you begin the process of removing the daughterboard, you will need to remove the port case. Using a Phillips #00 screwdriver, remove the three 4.6mm screws.
  8. Samsung Chromebook 3 Daughterboard Replacement: étape 8, image 1 de 2 Samsung Chromebook 3 Daughterboard Replacement: étape 8, image 2 de 2
    • Use a spudger to unhook the cable connecter from the speaker cable.
  9. Samsung Chromebook 3 Daughterboard Replacement: étape 9, image 1 de 3 Samsung Chromebook 3 Daughterboard Replacement: étape 9, image 2 de 3 Samsung Chromebook 3 Daughterboard Replacement: étape 9, image 3 de 3
    • Pry the small coaxial cables upwards from the connecters on the wireless chip.
  10. Samsung Chromebook 3 Daughterboard Replacement: étape 10, image 1 de 2 Samsung Chromebook 3 Daughterboard Replacement: étape 10, image 2 de 2
    • Using the Phillips #00, unscrew one 4.6mm screw from the daughterboard.
  11. Samsung Chromebook 3 Daughterboard Replacement: étape 11, image 1 de 3 Samsung Chromebook 3 Daughterboard Replacement: étape 11, image 2 de 3 Samsung Chromebook 3 Daughterboard Replacement: étape 11, image 3 de 3
    • Use a spudger to lift the gray plastic bar on the zif connecter up, then use your fingers to remove the cable ribbon.
  12. Samsung Chromebook 3 Daughterboard Replacement: étape 12, image 1 de 1
    • Loosen the daughterboard from the USB port with a spudger as there is some adhesive underneath, and you're ready to remove the daughterboard.
3 autres ont terminé cette réparation.
Sarah Westberg
Membre depuis le 03/11/19
23 167 Réputation
70 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 820 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 11
Total : 1,190
