Aller au contenu principal
Samsung Chromebook 3 Speakers Replacement
Ce dont vous avez besoin
  1. Samsung Chromebook 3 Speakers Replacement, Bottom Case: étape 1, image 1 de 2 Samsung Chromebook 3 Speakers Replacement, Bottom Case: étape 1, image 2 de 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Speakers Replacement: étape 2, image 1 de 3 Samsung Chromebook 3 Speakers Replacement: étape 2, image 2 de 3 Samsung Chromebook 3 Speakers Replacement: étape 2, image 3 de 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Speakers Replacement: étape 3, image 1 de 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Speakers Replacement, Speakers: étape 4, image 1 de 2 Samsung Chromebook 3 Speakers Replacement, Speakers: étape 4, image 2 de 2
    • Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
  5. Samsung Chromebook 3 Speakers Replacement: étape 5, image 1 de 3 Samsung Chromebook 3 Speakers Replacement: étape 5, image 2 de 3 Samsung Chromebook 3 Speakers Replacement: étape 5, image 3 de 3
    • Remove one 4.9mm silver screw from each speaker with a Phillips #00 screwdriver.
  6. Samsung Chromebook 3 Speakers Replacement: étape 6, image 1 de 3 Samsung Chromebook 3 Speakers Replacement: étape 6, image 2 de 3 Samsung Chromebook 3 Speakers Replacement: étape 6, image 3 de 3
    • Use a plastic spudger to gently coax the cable connecter sideways from the motherboard and the left speaker. When disconnected, remove speaker.
  7. Samsung Chromebook 3 Speakers Replacement: étape 7, image 1 de 3 Samsung Chromebook 3 Speakers Replacement: étape 7, image 2 de 3 Samsung Chromebook 3 Speakers Replacement: étape 7, image 3 de 3
    • Use a plastic spudger to gently disconnect the cable connecter from the daughterboard and the right speaker. Remove the speaker.
Sarah Westberg
Membre depuis le 03/11/19
23 251 Réputation
70 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 228 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 17
Total : 528
