Aller au contenu principal
Samsung Galaxy Buds Live Battery Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Buds Live Battery Replacement, Insert an opening pick: étape 1, image 1 de 2 Samsung Galaxy Buds Live Battery Replacement, Insert an opening pick: étape 1, image 2 de 2
    • If possible, discharge your Galaxy Buds Live before replacing the battery.
    • Place the tip of an opening pick between the plastic cases on the curved inside of the earbud.
    • Insert the pick at a steep angle.
  2. Samsung Galaxy Buds Live Battery Replacement, Loosen the case: étape 2, image 1 de 2 Samsung Galaxy Buds Live Battery Replacement, Loosen the case: étape 2, image 2 de 2
    • Keep the opening pick at a steep angle and slide it along the top to loosen the case.
    • Take your time and do your best not to deform the plastic.
  3. Samsung Galaxy Buds Live Battery Replacement, Remove the case: étape 3, image 1 de 2 Samsung Galaxy Buds Live Battery Replacement, Remove the case: étape 3, image 2 de 2
    • Remove the case.
  4. Samsung Galaxy Buds Live Battery Replacement, Disconnect the main connector: étape 4, image 1 de 2 Samsung Galaxy Buds Live Battery Replacement, Disconnect the main connector: étape 4, image 2 de 2
    • Use the pointed end of a spudger to lift up and disconnect the main connector.
  5. Samsung Galaxy Buds Live Battery Replacement, Remove the motherboard: étape 5, image 1 de 3 Samsung Galaxy Buds Live Battery Replacement, Remove the motherboard: étape 5, image 2 de 3 Samsung Galaxy Buds Live Battery Replacement, Remove the motherboard: étape 5, image 3 de 3
    • Use a spudger to gently lift up the motherboard.
    • Remove the motherboard.
  6. Samsung Galaxy Buds Live Battery Replacement, Unscrew the plastic frame: étape 6, image 1 de 1
    • Use a Phillips screwdriver to remove the 3.4 mm-long screw which is securing the plastic frame.
  7. Samsung Galaxy Buds Live Battery Replacement, Remove the plastic frame: étape 7, image 1 de 3 Samsung Galaxy Buds Live Battery Replacement, Remove the plastic frame: étape 7, image 2 de 3 Samsung Galaxy Buds Live Battery Replacement, Remove the plastic frame: étape 7, image 3 de 3
    • Use a spudger or your fingers to remove the plastic frame by pulling it upwards.
  8. Samsung Galaxy Buds Live Battery Replacement, Clear the battery: étape 8, image 1 de 2 Samsung Galaxy Buds Live Battery Replacement, Clear the battery: étape 8, image 2 de 2
    • Use the pointed end of a spudger to slightly lift up the speaker driver obscuring the battery.
    • The driver is held in place with light adhesive. Work carefully and don't tug on anything too hard.
  9. Samsung Galaxy Buds Live Battery Replacement, Pry up the battery: étape 9, image 1 de 3 Samsung Galaxy Buds Live Battery Replacement, Pry up the battery: étape 9, image 2 de 3 Samsung Galaxy Buds Live Battery Replacement, Pry up the battery: étape 9, image 3 de 3
    • The battery is held in place by a mild adhesive.
    • Insert the pointed end of a spudger underneath the battery.
    • Use constant, steady pressure to pry the battery up.
  10. Samsung Galaxy Buds Live Battery Replacement, Remove the battery: étape 10, image 1 de 1
    • Remove the battery.
    • Do not reinstall a damaged battery, as doing so is a potential safety hazard.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
10 autres ont terminé cette réparation.
Adriana Zwink
Membre depuis le 12/18/19
48 386 Réputation
167 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 125 tutoriels rédigés
Un commentaire
Thanks!!! This works great to clean the felt earwax filter underneath the metal grate as well!
Erin Rodriguez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 144
30 derniers jours : 725
Total : 14,904
