Aller au contenu principal
Samsung Galaxy Prevail 2 Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: étape 1, image 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: étape 1, image 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: étape 1, image 3 de 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: étape 2, image 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: étape 2, image 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: étape 2, image 3 de 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: étape 3, image 1 de 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: étape 3, image 2 de 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: étape 4, image 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: étape 4, image 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: étape 4, image 3 de 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone to pry off the front frame.
    • Make sure to pry around the entire frame before attempting to loosen it.
    • Push the motherboard out using your thumbs as shown
  5. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: étape 5, image 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: étape 5, image 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: étape 5, image 3 de 3
    • Lift the flap up using the plastic prying tool.
  6. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: étape 6, image 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: étape 6, image 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: étape 6, image 3 de 3
    • Lift the second flap to detach the motherboard completely.
  7. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: étape 7, image 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: étape 7, image 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: étape 7, image 3 de 3
    • With plastic prying tool, lift the flap connected to the camera (indicated in red) to remove it.
    • Be sure that you are looking at the back face of the motherboard.
  8. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: étape 8, image 1 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: étape 8, image 2 de 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: étape 8, image 3 de 3
    • Carefully lift and remove the camera from its position.
8 autres ont terminé cette réparation.
Alexandra Hernandez
Membre depuis le 10/08/14
741 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 14-4, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,394
