Aller au contenu principal
Samsung Galaxy Tab S3 Daughterboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Tab S3 Daughterboard Replacement, Display: étape 1, image 1 de 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Daughterboard Replacement: étape 2, image 1 de 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Daughterboard Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Daughterboard Replacement: étape 4, image 1 de 3 Samsung Galaxy Tab S3 Daughterboard Replacement: étape 4, image 2 de 3 Samsung Galaxy Tab S3 Daughterboard Replacement: étape 4, image 3 de 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Daughterboard Replacement, Rear glass panel: étape 5, image 1 de 2 Samsung Galaxy Tab S3 Daughterboard Replacement, Rear glass panel: étape 5, image 2 de 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Daughterboard Replacement, Battery: étape 6, image 1 de 2 Samsung Galaxy Tab S3 Daughterboard Replacement, Battery: étape 6, image 2 de 2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Daughterboard Replacement: étape 7, image 1 de 1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Daughterboard Replacement: étape 8, image 1 de 3 Samsung Galaxy Tab S3 Daughterboard Replacement: étape 8, image 2 de 3 Samsung Galaxy Tab S3 Daughterboard Replacement: étape 8, image 3 de 3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Daughterboard Replacement: étape 9, image 1 de 2 Samsung Galaxy Tab S3 Daughterboard Replacement: étape 9, image 2 de 2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Daughterboard Replacement: étape 10, image 1 de 2 Samsung Galaxy Tab S3 Daughterboard Replacement: étape 10, image 2 de 2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Daughterboard Replacement: étape 11, image 1 de 1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Daughterboard Replacement, Daughterboard: étape 12, image 1 de 3 Samsung Galaxy Tab S3 Daughterboard Replacement, Daughterboard: étape 12, image 2 de 3 Samsung Galaxy Tab S3 Daughterboard Replacement, Daughterboard: étape 12, image 3 de 3
    • Use a spudger to pry up four press fit connectors from the lower board containing the charging port.
  13. Samsung Galaxy Tab S3 Daughterboard Replacement: étape 13, image 1 de 3 Samsung Galaxy Tab S3 Daughterboard Replacement: étape 13, image 2 de 3 Samsung Galaxy Tab S3 Daughterboard Replacement: étape 13, image 3 de 3
    • Pry up the two coaxial cables joining the daughterboard to the motherboard.
    • Be sure to pull the white coaxial cable from the small bracket holding the wire to the daughterboard before removal.
  14. Samsung Galaxy Tab S3 Daughterboard Replacement: étape 14, image 1 de 3 Samsung Galaxy Tab S3 Daughterboard Replacement: étape 14, image 2 de 3 Samsung Galaxy Tab S3 Daughterboard Replacement: étape 14, image 3 de 3
    • Pry the daughterboard up from the midframe with a spudger.
    • Remove the daughterboard.
3 autres ont terminé cette réparation.
Austin Blakely
Membre depuis le 03/11/19
19 536 Réputation
53 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 198 tutoriels rédigés
3 commentaires
Do you need to remove the front display assembly to replace the daughterboard? From the images it appears you just have to go in through the back glass to do this job. Confused.
Grant Ormsby - Réponse
You do, because the midframe is adhered to both the front and back. It won't come off if you just take off the back.
Flint Green -
You don't have to take screen off. Just disconnect battery.
Jake Fowler - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 43
Total : 2,086
