Aller au contenu principal
Samsung Gear Fit Screen Replacement
Ce dont vous avez besoin
  1. Samsung Gear Fit Screen Replacement, Watch Band: étape 1, image 1 de 2 Samsung Gear Fit Screen Replacement, Watch Band: étape 1, image 2 de 2
    • Place your thumbs on the ends of the screen.
    • Push the watch outward while pulling the band away from the watch.
  2. Samsung Gear Fit Screen Replacement, Screen: étape 2, image 1 de 1
    • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
    • For step-by-step instructions on using an iOpener, see the Instructions iOpener.
    • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
  3. Samsung Gear Fit Screen Replacement: étape 3, image 1 de 3 Samsung Gear Fit Screen Replacement: étape 3, image 2 de 3 Samsung Gear Fit Screen Replacement: étape 3, image 3 de 3
    • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
    • Gently pry the screen loose using a plastic opening tool.
    • If the screen doesn't easily come loose, more heating may be required
  4. Samsung Gear Fit Screen Replacement: étape 4, image 1 de 3 Samsung Gear Fit Screen Replacement: étape 4, image 2 de 3 Samsung Gear Fit Screen Replacement: étape 4, image 3 de 3
    • Using tweezers as a lever, pry the inner assembly out of the external casing.
    • This will be harder than removing the screen. Moderate force may be required.
  5. Samsung Gear Fit Screen Replacement: étape 5, image 1 de 3 Samsung Gear Fit Screen Replacement: étape 5, image 2 de 3 Samsung Gear Fit Screen Replacement: étape 5, image 3 de 3
    • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
  6. Samsung Gear Fit Screen Replacement: étape 6, image 1 de 2 Samsung Gear Fit Screen Replacement: étape 6, image 2 de 2
    • Gently peel the screen assembly up and away from the device using tweezers.
17 autres ont terminé cette réparation.
Nathan Powell
Membre depuis le 04/24/14
1 577 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 11-49, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 11-49, Amido Spring 2014
CPSU-AMIDO-S14S11G49
4 membres
4 tutoriels rédigés
28 commentaires
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - Réponse
Where can you buy replacement screen?
Yele Olaniyi - Réponse
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - Réponse
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - Réponse
Does anyone know where to get the replacement screen?
MrGratts - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 53,427
