Aller au contenu principal
Sonos One Control Panel & Microphone Replacement
Ce dont vous avez besoin
  1. Sonos One Control Panel & Microphone Replacement, Protective Cover: étape 1, image 1 de 3 Sonos One Control Panel & Microphone Replacement, Protective Cover: étape 1, image 2 de 3 Sonos One Control Panel & Microphone Replacement, Protective Cover: étape 1, image 3 de 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Control Panel & Microphone Replacement: étape 2, image 1 de 3 Sonos One Control Panel & Microphone Replacement: étape 2, image 2 de 3 Sonos One Control Panel & Microphone Replacement: étape 2, image 3 de 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Control Panel & Microphone Replacement: étape 3, image 1 de 2 Sonos One Control Panel & Microphone Replacement: étape 3, image 2 de 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Control Panel & Microphone Replacement: étape 4, image 1 de 3 Sonos One Control Panel & Microphone Replacement: étape 4, image 2 de 3 Sonos One Control Panel & Microphone Replacement: étape 4, image 3 de 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Control Panel & Microphone Replacement: étape 5, image 1 de 2 Sonos One Control Panel & Microphone Replacement: étape 5, image 2 de 2
    • Slide the protective cover upwards to remove.
  6. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: étape 6, image 1 de 3 Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: étape 6, image 2 de 3 Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: étape 6, image 3 de 3
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  7. Sonos One Control Panel & Microphone Replacement: étape 7, image 1 de 2 Sonos One Control Panel & Microphone Replacement: étape 7, image 2 de 2
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
  8. Sonos One Control Panel & Microphone Replacement: étape 8, image 1 de 3 Sonos One Control Panel & Microphone Replacement: étape 8, image 2 de 3 Sonos One Control Panel & Microphone Replacement: étape 8, image 3 de 3
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
  9. Sonos One Control Panel & Microphone Replacement: étape 9, image 1 de 2 Sonos One Control Panel & Microphone Replacement: étape 9, image 2 de 2
    • Pull the control panel away from the speaker to separate.
Marcus Glowa
Membre depuis le 02/14/18
848 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G1, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 membres
6 tutoriels rédigés
Un commentaire
where can I buy a replacement control panel?
Chris Myers - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 60
Total : 6,174
