Aller au contenu principal
Sony Xperia XZ Premium Front Camera Replacement
Ce dont vous avez besoin
  1. Sony Xperia XZ Premium Front Camera Replacement, Back Panel: étape 1, image 1 de 1
    • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
    • Follow this guide for directions on using the iOpener.
  2. Sony Xperia XZ Premium Front Camera Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
  3. Sony Xperia XZ Premium Front Camera Replacement: étape 3, image 1 de 1
    • Take hold of the back panel with your fingers and remove.
  4. Sony Xperia XZ Premium Front Camera Replacement, Front Camera: étape 4, image 1 de 1
    • Remove the two bottom left 3.9 mm Phillips #000 screws.
  5. Sony Xperia XZ Premium Front Camera Replacement: étape 5, image 1 de 1
    • Insert the spudger under the bottom left frame and lift, try to lift vertically to wedge it out.
  6. Sony Xperia XZ Premium Front Camera Replacement: étape 6, image 1 de 1
    • Grab hold of the bottom left frame and lift out carefully.
  7. Sony Xperia XZ Premium Front Camera Replacement: étape 7, image 1 de 1
    • Insert a spudger under the tab above the camera and lift to disconnect it.
  8. Sony Xperia XZ Premium Front Camera Replacement: étape 8, image 1 de 1
    • Grab hold of the tab with your fingers.
  9. Sony Xperia XZ Premium Front Camera Replacement: étape 9, image 1 de 1
    • Lift the camera from the phone by the tab.
Gelene Amog
Membre depuis le 04/18/18
1 165 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S18-G2, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
5 membres
16 tutoriels rédigés
Un commentaire
The name of this tutorial is incorrect.
Gavin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 2,153
