Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Surface Laptop Studio Battery Replacement
Ce dont vous avez besoin
  1. Surface Laptop Studio Battery Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
    Demander à FixBot
    Ajouter un commentaire
  2. Surface Laptop Studio Battery Replacement: étape 2, image 1 de 2 Surface Laptop Studio Battery Replacement: étape 2, image 2 de 2
    • Use a hair dryer to lightly heat the rubber feet to soften the adhesive securing them to the case.
    • Remove the two rubber feet on the lower case with an opening tool.
    • If you intend to reuse the rubber feet, take care not to warp, stretch, or tear them during removal.
    Demander à FixBot
  3. Surface Laptop Studio Battery Replacement: étape 3, image 1 de 1
    • Remove the two screws with a T3 Torx screwdriver.
    Demander à FixBot
  4. Surface Laptop Studio Battery Replacement: étape 4, image 1 de 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
    Demander à FixBot
  5. Surface Laptop Studio Battery Replacement: étape 5, image 1 de 2 Surface Laptop Studio Battery Replacement: étape 5, image 2 de 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
    Demander à FixBot
  6. Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: étape 6, image 1 de 2 Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: étape 6, image 2 de 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
    Demander à FixBot
  7. Surface Laptop Studio Battery Replacement, Battery: étape 7, image 1 de 2 Surface Laptop Studio Battery Replacement, Battery: étape 7, image 2 de 2
    • Pull the pull tabs to release the adhesive securing the battery.
    • Remove the battery.
    • You will need to reattach the new battery with adhesive.
    Demander à FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.c
Nate Ball
Membre depuis le 02/14/23
756 Réputation
5 tutoriels rédigés
Équipe
7 commentaires de tutoriel
Where can I find a Surface Studio Laptop battery? Microsoft seems to have been out of stock for a while now.
Omar Abouelseoud - Réponse Partager
Are the rubber feet re-attachable to the laptop after repairs?
Any link to buy the battery ?
Alberto Guinea (Shlenderman) - Réponse Partager
The what you need section should also mention Surface Laptop Studio Cosmetic Plate - Genuine, possibly as an optional part.
Ronno Das - Réponse Partager
Great point, Ronno! We added that to the parts list. Thanks for your comment.
Connor Bassolino - Réponse Partager
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 91
30 derniers jours : 532
Total : 15,528
