Outils
Aucun outil requis.
Pièces
Vidéo d'introduction
Take your time! Use a guitar pick, although some have successfully used a fingernail. Don't use a screwdriver as you will damage the case.
  • Take your time!
    • Use a guitar pick, although some have successfully used a fingernail. Don't use a screwdriver as you will damage the case.
    • Start at one corner and carefully insert your tool, working it along the seam until you hear a click and the case starts to come apart.
    • Carry on working your way around the case. Be very careful near the buttons.
    • Eventually the rear case will come away. There aren't any wires attached to the rear case, it just lifts off.
    • When it's time to reassemble, clip the rear cover back on carefully, making sure to fit the side with the buttons first and being careful to ensure they are positioned correctly.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
The case will remove in one piece and look like the below once done.
  • The case will remove in one piece and look like the below once done.
Carefully peel off the black sticky tape and set it aside. Don't damage the twisted wire leading to the speaker. Unscrew the two screws holding the port in place.
  • Carefully peel off the black sticky tape and set it aside.
  • Don't damage the twisted wire leading to the speaker.
  • Unscrew the two screws holding the port in place.
  • Remove the two pin speaker plug by moving it gently from side to side until it comes out of its socket.
  • Use a spudger to flip open the latch and then withdraw the flat cable.
  • Lift out the board and replace with a new one. Reattach the black sticky tape.
Ligne d'arrivée
Tim
Membre depuis le 31/08/2010
610 Réputation
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 32
Total : 63
